Turbo integra ls should I swap to gsr or si tranny
Old Mar 28, 2006 | 05:28 PM
xaikolee's Avatar
Default Turbo integra ls should I swap to gsr or si tranny
I was wondering if I should change from my Ls tranny to a gsr or si tranny. Would it help as in speed. Low end or high end. Any input would help thanks.
Old Mar 28, 2006 | 06:10 PM
Benard's Avatar
ls tranny will give you longer gear ratios for higher top speed and better gas milage...wheras an si tranny would give the best low end and accelleration...and the gsr would be in between the two....
Im sure someone can chime in with the final drive ratios if you really want to know the exacts
Old Mar 28, 2006 | 06:11 PM
Benard's Avatar
Also i believe the gsr tranny is the strongest of the b-series trannys, due to dual cone syncros
Old Apr 1, 2006 | 08:06 AM
Cole D's Avatar
Default Re: (Benard)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Benard &raquo;</TD></TR><TR><TD CLASS="quote">ls tranny will give you longer gear ratios for higher top speed and better gas milage...wheras an si tranny would give the best low end and accelleration...and the gsr would be in between the two....
Im sure someone can chime in with the final drive ratios if you really want to know the exacts</TD></TR></TABLE>
The ls is a dog when it comes to accleration get a gsr or b16 tranny and swap your LS 5th gear in it. Best of both worlds
Old Apr 1, 2006 | 09:27 AM
TurboGS-R's Avatar
Default Re: (Cole D)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cole D &raquo;</TD></TR><TR><TD CLASS="quote">The ls is a dog when it comes to accleration get a gsr or b16 tranny and swap your LS 5th gear in it. Best of both worlds </TD></TR></TABLE>
good idea. I would suggest getting the GS-R tranny.
Old Apr 1, 2006 | 09:31 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: Turbo integra ls should I swap to gsr or si tranny (xaiko)
Whatever transmission you choose, consider adding an LSD.
Old Apr 1, 2006 | 09:58 AM
SlammedDC2teg's Avatar
Default Re: Turbo integra ls should I swap to gsr or si tranny (Dogginator)
Also the ls tranny will let you stay in the boost longer and give you better HP. I wouldnt swap a gsr tranny on a 65 hundred redline.
Old Apr 1, 2006 | 10:32 AM
shamoo's Avatar
Will you make something up for me please?
Default Re: Turbo integra ls should I swap to gsr or si tranny (SlammedDC2teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlammedDC2teg &raquo;</TD></TR><TR><TD CLASS="quote">Also the ls tranny will let you stay in the boost longer and give you better HP. I wouldnt swap a gsr tranny on a 65 hundred redline.</TD></TR></TABLE>
Incorrect. Shorter gear ratios will ALWAYS be faster. Horsepower remains the same, but mechanical advantage increases with shorter ratios. The original poster will need to decide whether he wants better gas mileage/higher top speed, or faster acceleration/lower top speed.
Old Apr 1, 2006 | 10:46 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: Turbo integra ls should I swap to gsr or si tranny (shamoo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shamoo &raquo;</TD></TR><TR><TD CLASS="quote">
Incorrect. Shorter gear ratios will ALWAYS be faster. Horsepower remains the same, but mechanical advantage increases with shorter ratios. The original poster will need to decide whether he wants better gas mileage/higher top speed, or faster acceleration/lower top speed. </TD></TR></TABLE>
I was wondering how long it would take for someone to bring the "longer gearing is better for boost" arguement. If you think that is the case, start in fifth gear.
Old Apr 1, 2006 | 02:36 PM
Danziver's Avatar
If you want to get another tranny i would get a gsr.
Old Apr 1, 2006 | 02:46 PM
Spec R's Avatar
Default Re: Turbo integra ls should I swap to gsr or si tranny (Danziver)
I have a GSR tranny mated to my B18B at 8psi. works great for me. 4k rpm at 80 mph.
GSR to LS 1st and 2nd are the same numerically, but the GSR has a shorter (numerically higher) final drive of 4.40 compared to the LS 4.26.
3rd 4th and 5th are shorter on the GSR.
Old Apr 1, 2006 | 05:35 PM
00IntegrAllmotoR's Avatar
HT Black OPs
Default Re: Turbo integra ls should I swap to gsr or si tranny (Spec R)
Dont plan on doing any long 5th gear pulls, with a B16 tranny. Unless you got a perfect tune.
Old Apr 1, 2006 | 07:27 PM
cm zak's Avatar
Dont boost 5th gear w/o engine management.
gsrpedro
33
Nov 8, 2009 06:19 PM
Adams5
Feb 1, 2004 05:26 PM
Boostage
Jan 16, 2004 03:56 PM
Forgiven
Feb 20, 2003 11:44 AM
torr
Jan 23, 2003 02:09 PM
