SHOCKing question
Old Mar 28, 2006 | 04:57 PM
cyang08's Avatar
Default SHOCKing question
i am gona be using 99 honda civic SI shocks on my 94 dx coupe. i need to buy new bushing cause my bushing bolt and bushing became one. and it seems as if my stock bushing on my dx wont work with my 99 si shocks. i havent got the new bushing yet. i was woundering if i use a 99 si bushing, will it fit on my 94 dx control arm???? i hope you guys understand what im saying. but yea i could use some help. Thanx
Old Mar 28, 2006 | 05:07 PM
Chong's Avatar
ballin
Default Re: SHOCKing question (cyang08)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cyang08 &raquo;</TD></TR><TR><TD CLASS="quote">i hope you guys understand what im saying.
Negatory.
Old Mar 28, 2006 | 05:24 PM
zacatkings's Avatar
Default Re: SHOCKing question (Chong)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chong &raquo;</TD></TR><TR><TD CLASS="quote">
Negatory.</TD></TR></TABLE>
roger captin um sending in more troops haha
Old Mar 28, 2006 | 06:10 PM
schardbody's Avatar
you will have to use the ek shock forks as well, the eg forks wont fit on the ek shocks, but the ek forks fit on the eg lower control arm, get what im saying.
Old Mar 28, 2006 | 06:11 PM
cyang08's Avatar
not really. pictures would help. what is the fork. is that where the the bushing bolt gose?
Old Mar 28, 2006 | 06:12 PM
cyang08's Avatar
first off i broke the bushing bolt while trying to put in lowering springs. then i found that there was no way of removing the rest of the bolt. so i was f*** it ill just cut the bottom of my shock mount to get the shock off. now i have to get a new bushing. the thick inner sleeve of the bushing looks as if it is to big and the 99 si shock mount wont fit. well if i just get a 99 si BUSHING. then will the 99 si shock fit, and will the 99 si bushing even fit into the whole on my 94 civic control arm??? the reason im putting 99 civic shocks on my car is i dont have any more 94 civic shocks and this is for temp only.
Old Mar 28, 2006 | 06:19 PM
bsixteen's Avatar
the shock fork is the Y looking piece. so you need the EK(99-00) shock forks that your 99-00 shocks were connected to, to connect on the LCA.
looks like the pic in this thread: http://hondamarketplace.com/zerothread?id=1083191
Old Mar 28, 2006 | 06:29 PM
schardbody's Avatar
right the fork is the part that bolts to the bottom of the shock and then to the LCA. if you cut that the shock is fine and you can re=use it, but would need a new shock fork and stock bushing.
Old Mar 28, 2006 | 06:56 PM
cyang08's Avatar
ok is that for the rear or front? cause the shocks im changing are the rear shocks.
Old Mar 28, 2006 | 07:27 PM
schardbody's Avatar
oh, ok, thats a differant ballgame all together. i dont think the rear shocks are interchangeable, unless the lca bushing is interchangeable.
Old Mar 28, 2006 | 08:01 PM
cyang08's Avatar
is it interchangeable?
Old Mar 29, 2006 | 04:22 AM
schardbody's Avatar
im not sure but i doubt it is.
Ariddle25
11
May 3, 2011 05:58 AM
Mewgen
Suspension & Brakes
May 18, 2006 07:37 AM
myronwong
12
Feb 5, 2006 03:47 PM
rogue420
Suspension & Brakes
Aug 25, 2005 10:36 AM
liam821
Aug 3, 2003 01:22 AM
