Car bogging hesitating
i have a 94 hatch with a jdm d15b swap in it. Car runs fine until its warmed up. When warmed up it boogs and hesitates really bad below 3500 rpm easpecially when at wot. Right after 3500 rpm it takes off like a rocket wtf. We changed the plugs, fuel filter, checked all of the sesors.(there was no codes). Were thinking it might be the o2 sensor or the injectors. Any other suggestions would help thanks.
[QUOTE= Car runs fine until its warmed up. When warmed up it boogs and hesitates really bad below 3500 rpm easpecially when at wot. Right after 3500 rpm it takes off like a rocket wtf QUOTE]
i have the same problem with my '96 d16y7 hatch. can someone please help me too?
Modified by EK tommy at 5:22 PM 3/28/2006
I have the same problem currently... It occured awhile back and found that its a mis-fire under wot. I changed the plugs and the problem was fixed but now its back again. Im going to check my cap and rotor next.
From what i have found its a definite misfire, it doesnt do it untill the car is warmed up right?
i just found out what was wrong with my car. i had a diagnostic done, and it was my "o2 sensor." the one before the cat. good luck!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK tommy »</TD></TR><TR><TD CLASS="quote">i just found out what was wrong with my car. i had a diagnostic done, and it was my "o2 sensor." the one before the cat. good luck! </TD></TR></TABLE>
Were you experiencing the same problems?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ForceFed_Motorsports »</TD></TR><TR><TD CLASS="quote">
Were you experiencing the same problems?</TD></TR></TABLE>
yup
yup
WeB
Feb 21, 2010 04:20 PM
