Upper Ctl. Arm Bushing causing SHAKE?
I have been having a shake in my wheel and actually my WHOLE car. It does it @ light acceleration and stops @ 60kmh. I just checked and my upper bushings are shot as ****. Could this be my problem?? Thanks in Advance
Yes, if the bushings or balljoint on your UCA are shot, then that corner is going to be a little shakey. While you're down there, check out your tie-rod ends and lower balljoint too, you might as well.
EFing8
Jul 19, 2009 11:19 PM
