Time To Change Tranny - Need Advice
Hey guys, I'm currently running an LSV setup (components in my sig) with my stock LS tranny. It sucks.. the LS tranny should be nowhere near an all-motor setup. Anyway, I'm on a budget and I'd like to know if throwing a better clutch and an 8lb flywheel in my LS tranny is going to be anywhere near the effect of having an actual GSR transmission? Also, about how much does a full GSR tranny swap run in Southern California? Regearing is also something to be considered if it's within reasonable means. I'm looking at no more than $400-$500
Thanks for the help
Thanks for the help
No, it won't be anywhere near a gsr trans, just putting a light flywheel in that is.
Unless you find a good deal on a tranny, you'll probably spend more then 500.
do you think it's worth putting in the lighter flywheel and better clutch? i'm not into competitive racing and i've done well in the canyon passes (retired) thus far. i guess i just want the feeling and assurance to know it's there when i need it. but yeah, do you think i should just go with the flywheel?
Lightweight flywheel will be a lot cheaper,
If you're not into racing, and it's more of a dd, then ls should work out good.
Unless you find a gsr trans cheap, stick with the flywheel.
and you can always bring all that over if you Do eventually find a gsr trans,
long as it's hydro&hydro and not mixing with cable.
Also, I have yet to, or actually never did get any kind of track times between my ls, and gsr trans, but it's not like you'll be seconds faster, or feel like you added 10-20hp.
changing your clutch and flywheel will only help put your power to the wheels and rev faster but if you're talking about an LS tranny not being good on all motor setups reliability wise, changing your clutch and flywheel wont do anything
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rockNrollteg »</TD></TR><TR><TD CLASS="quote">alright, good info. i'll go with the clutch and flywheel for now and see how i like it. if it's not enough, i'll spring for the tranny and get the best of both. thanks.</TD></TR></TABLE>
Good idea, you can always buy a good clutch & Flywheel now , then save up for your GS-R Tranny. Then When you get the GS-R tranny you'll have a sweet setup alreay having the Clutch and lightweight flywheel
get a jdm b16 w/lsd and ill install it for you at my shop (at a small minimal cost of course!) get the clutch and flywheel too. lightened flywheels are the **** on NA cars. id get the lowest gearing possible to make use of the torque curve on your LS/V. Honestly ive seen b16a trans go for like 600-900 bucks! look around
i have LS-V and im running 96' spec ITR trans. LSD is king.
see, i was GONNA get a b16 just for the quickness off the line, but then i daily my car....so i got a ITR for the final gear....and LSD.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hothotpete »</TD></TR><TR><TD CLASS="quote">i have LS-V and im running 96' spec ITR trans. LSD is king.
how much were you able to get yours for? i don't think i can spring for 1200 bucks on an ITR. guess i'll have to get the GSR tranny. i don't even know where to begin to look.
</TD></TR></TABLE>how much were you able to get yours for? i don't think i can spring for 1200 bucks on an ITR. guess i'll have to get the GSR tranny. i don't even know where to begin to look.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by typerhedlights »</TD></TR><TR><TD CLASS="quote">ask not so civic on here. pm he can build you a custom tranny. im getting a trans. with gears 1-4 from gsr and 5th from an LS with itr lsd and final drive for 900 shipped!
i bought a ls tranny from him!
</TD></TR></TABLE>i bought a ls tranny from him!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FlatBlackTeg »</TD></TR><TR><TD CLASS="quote">Lightweight flywheel will be a lot cheaper,
Also, I have yet to, or actually never did get any kind of track times between my ls, and gsr trans, but it's not like you'll be seconds faster, or feel like you added 10-20hp.</TD></TR></TABLE>
Same here. I just got my gsr engine swap, as far as gearing its not a mindblowing experience but 3rd gear is good though. B series hydro trannys are becoming harder to find. I would expect to pay about 600+ for a good gsr and 800+ for a good b16.
Kp_VtekNiks
Apr 21, 2002 09:07 AM
