GSR block vs LS block?
Old Mar 27, 2006 | 09:28 PM
delsol4me's Avatar
Default GSR block vs LS block?
what is the difference between these 2 blocks? is 1 thicker, made of different material? just was wondering.... if there is a link or somthing just show me, thanks.
Old Mar 27, 2006 | 10:14 PM
delsol4me's Avatar
Default Re: GSR block vs LS block? (makemoney)
alright thanks just curious about it....
Old Mar 28, 2006 | 03:41 AM
so lazy's Avatar
Default Re: GSR block vs LS block? (delsol4me)
Gsr block has like a higher compression piston and a shorter stroke as the LS block has like a lower compression piston if i dont recall but with a LONGER stroke... now a vtec head onto a ls block will bump the compression up for a torque monster... if your going with all motor i would go with a LS block and slap a vtec head on it but GSR will do good also.. both are good blocks i say just the GSR has better water pump and oil pump cause of the VTEC.. but you can alway swap that out to the LS block it'll bolt right up...
Old Mar 28, 2006 | 05:21 AM
Honda Bull's Avatar
Default Re: GSR block vs LS block? (dc2-guy)
Both are aluminum. GSR block has oil passages for a VTEC head. LS block doesn't.
The whole complete bottom end differs even more.
Old Mar 28, 2006 | 09:34 AM
so lazy's Avatar
Default Re: GSR block vs LS block? (Honda Bull)
thanks honda bull.
Old Mar 29, 2006 | 10:41 AM
projectTeG's Avatar
the blocks themselfs are made out of the same materials. the gsr block has oil squirters for added cooling on the pistons, the gsr block has a shorter stroke crank and longer rods for less side wall load on the engine at higher rpms, the pistons are 10.2(usdm) 10.4(jdm). gsr blocks have tri-metal bearings
the ls block has a no oil squirters, its has a larger stroke with shorter rods for more usable power in the low rpms. the added stroke adds more sidewall load on the engine at higher rpms. ls blocks have bi-metal bearings.the pistons are 9.2(usdm)&9.4(jdm)
Modified by projectTeG at 8:29 PM 3/29/2006
Old Mar 29, 2006 | 11:17 AM
JDMC-Kamel's Avatar
Default Re: (projectTeG)
nice somebody knows!!!
Justlearning95
Sep 21, 2016 07:09 AM
DCM
Oct 15, 2009 03:36 PM
rider07
Aug 10, 2007 10:06 AM
ABCVTEC
14
Nov 15, 2006 08:59 AM
jamal-188
Apr 29, 2002 05:40 AM
