b2 bottom end, a6 head. same timing? if not how to adjust plz.
Old Mar 27, 2006 | 07:06 PM
dohc_profile's Avatar
Default b2 bottom end, a6 head. same timing? if not how to adjust plz.
im replacing my d15b2 head with a d16a6 head. the a6 has about 150 less k on it, and a more agrressive cam so it'll be good to have. i want to put the head on my block. keeping the DPFI (if that matters) not converting to MPFI. i just want to know if the timing is the same and if it isnt how do i adjust is and by wut specs? thanks guys. one more thing... im replacing the gasket. i buy an a6 head gasket correct?
Old Mar 28, 2006 | 08:14 PM
Default Re: b2 bottom end, a6 head. same timing? if not how to adjust plz. (dseries_ef)
bump.
Old Mar 28, 2006 | 08:52 PM
poundedhatchcrap's Avatar
I have done this my self before and it works fine. If I remember correct the b2 and a6 heads are from the same casting just with a different cam(dont quote me) I used the head gasket for a b2, but the box says b2,b1,a6 etc.
Old Mar 29, 2006 | 02:25 AM
91CivicHatchback's Avatar
in order to use the a6 cam gear in a b2 head u have to have either a y7 gear or adjustable cam gear, their 4.5 degrees diffrent..theres a small diffrence with the cam and DPFI, but not as much as u would see with MPFI
Old Mar 29, 2006 | 05:53 AM
dr_latino999's Avatar
Default Re: b2 bottom end, a6 head. same timing? if not how to adjust plz. (poundedsedan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poundedsedan &raquo;</TD></TR><TR><TD CLASS="quote">I have done this my self before and it works fine. If I remember correct the b2 and a6 heads are from the same casting just with a different cam(dont quote me) I used the head gasket for a b2, but the box says b2,b1,a6 etc. </TD></TR></TABLE> But you are right, so I will quote you.
HEAD Castings where Honda was lazy and used the same mold
D15B1
D15B2
D15B7
D16A6
If you can, use a head gasket from a D16Z6 or D16Y8 (Same thing but one may be more expensive then the other), not for the compression increase but for the "I'm a metal head gasket and won't leave a hell of a mess like my paper counterparts."
Old Mar 29, 2006 | 04:56 PM
so putting my a6 head onto my b2 bottom would be a direct plug n play swap then? really dont wanna expletive things up lol. i tought the same was the only real difference, just wanted to make sure the timing was the same between the b2 bototm end and a6 head. thank for hte help
Old Mar 29, 2006 | 05:01 PM
Default Re: (dseries_ef)
If you want to specify timing, there is a 4.5 degree timing difference between the B2 cam and the A6 cam.
Old Mar 29, 2006 | 05:08 PM
crxnj's Avatar
Default Re: (91CivicHatchback)
I would definately get the (d16z6)metal gasket over the stock paper version..And for timing issue you can get an adjustable cam gear..
Old Mar 29, 2006 | 05:16 PM
silentdork818's Avatar
Default Re: (Mr.speaker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 &raquo;</TD></TR><TR><TD CLASS="quote">If you want to specify timing, there is a 4.5 degree timing difference between the B2 cam and the A6 cam.</TD></TR></TABLE>
Is it 4.5 degrees retarded or advanced?
Old Mar 29, 2006 | 05:25 PM
im not swtching just the cam... the whole head...or do i still have to adjust the cam? or is it not necessary to adjust it?
Old Mar 29, 2006 | 06:14 PM
Default Re: (silentdork818)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silentdork818 &raquo;</TD></TR><TR><TD CLASS="quote">Is it 4.5 degrees retarded or advanced?</TD></TR></TABLE> That I don't remember, I do know Mista_Bone knows.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dseries_ef &raquo;</TD></TR><TR><TD CLASS="quote">im not swtching just the cam... the whole head...or do i still have to adjust the cam? or is it not necessary to adjust it?</TD></TR></TABLE> Still need to adjust
Old Mar 29, 2006 | 06:29 PM
ok so the cam is the only adjusting i need to do? and buy an adjustable cam gear? any suggestions. and how do i go about adjusting it? never swapped a head before and wanna make this succesful.
Old Mar 29, 2006 | 06:31 PM
http://cgi.ebay.com/ebaymotors...ZWDVW
AEm good **** i would assume.. or is spending this much money neccessary?
do i just put this ontot he cam and instlala nd its good to go?
Old Mar 29, 2006 | 08:08 PM
crxnj's Avatar
I recomend megan racing cam gear(s)..Ive used megan,older aem,and skunk2 and the megan was the best in my opinion..
Old Mar 30, 2006 | 12:55 AM
aaronhume's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dseries_ef &raquo;</TD></TR><TR><TD CLASS="quote">ok so the cam is the only adjusting i need to do? and buy an adjustable cam gear? any suggestions. and how do i go about adjusting it? never swapped a head before and wanna make this succesful. </TD></TR></TABLE>
about a year ago i swapped the A6 cam into my B2 engine, and had it pretty figured out so i didn't have to use an adjustable gear, but if you want it perfect you need one.
check it out:
https://honda-tech.com/zerothread?id=1148138
kauai96
Apr 8, 2024 12:41 PM
#Leo#
Mar 22, 2010 09:54 AM
turbocivic1984
Jun 2, 2008 03:03 PM
donnjuan2point2
Sep 16, 2003 09:18 AM
