anyone know it buddy clubs p1 QF fit over spoon brakes 35mm offset
Old Mar 27, 2006 | 04:35 PM
ekim952522000's Avatar
Default anyone know it buddy clubs p1 QF fit over spoon brakes 35mm offset
I saw that a 42mm offset clears by searching
But mine are 35mm offset and wondering if they will work I have the brakes on order and was wondering if i need to buy spacers...
Old Mar 27, 2006 | 06:03 PM
white rocket's Avatar
Default Re: anyone know it buddy clubs p1 QF fit over spoon brakes 35mm offset (ekim952522000)
Are we talking about a 15x7 wheel? If the 42mm offset fits then you should not have a problem with the 35mm. I believe 38mm works fine too.
I run a 43mm offset and I think I'll have to run either a 3mm or 5mm spacer.
Old Mar 27, 2006 | 09:59 PM
Default Re: anyone know it buddy clubs p1 QF fit over spoon brakes 35mm offset (white rocket)
15x7 yeah
Are you saying the 35mm has more clearance?
Sorry I'm a complete moron when it comes to wheel offset's
Old Mar 28, 2006 | 12:27 AM
RagingAngel's Avatar
Oversimplified...it's...the lower the number the further it will stick out of fenders. (+35mm)
The higher the number the closer it will be to the suspension components (+42mm)
With the +35mm you will have a LOT of clearance.
Old Mar 28, 2006 | 05:56 AM
Default Re: anyone know it buddy clubs p1 QF fit over spoon brakes 35mm offset (RagingAngel)
Thanks a million
Old Mar 28, 2006 | 06:09 AM
Reid's Avatar
Global Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RagingAngel &raquo;</TD></TR><TR><TD CLASS="quote">Oversimplified...it's...the lower the number the further it will stick out of fenders. (+35mm)
With the +35mm you will have a LOT of clearance. </TD></TR></TABLE>
While I understand your point and that you were making a generalization, I would warn that it is dangerous to make a decision based on this logic alone.
For example, 350Z/G35's without the factory Brembos can run a lower offset wheel compared to those with Brembos. The cars with Brembos require a higher offset wheel to clear the calipers.
It all comes down to wheel design I suppose. Test fitting is the only way to know for sure how it will fit.
Old Mar 28, 2006 | 07:50 AM
JjuuN R's Avatar
grrr, i wish my Spoon Calis were on order
Old Mar 28, 2006 | 08:46 AM
Default Re: anyone know it buddy clubs p1 QF fit over spoon brakes 35mm offset (Reid)
I know you mean well Reid...
I shoulda clarified that I've had the exact same wheels in the +42mm offset so I know they fit for sure.... esp with a +35mm
https://honda-tech.com/zerothread?id=1393185
Old Mar 28, 2006 | 08:52 AM
Reid's Avatar
Global Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RagingAngel &raquo;</TD></TR><TR><TD CLASS="quote">I shoulda clarified that I've had the exact same wheels in the +42mm offset so I know they fit for sure.... esp with a +35mm
Good info.
Old Mar 28, 2006 | 01:14 PM
THanks alot guys
Yeah I love the wheels there crazy light
papa5murf
Honda S2000
104
Oct 4, 2015 09:09 AM
Turbo O
Feb 20, 2011 10:27 AM
bassplayer
Suspension & Brakes
Jan 5, 2010 03:49 PM
MessGSR
Honda Civic (2006 - 2015)
15
Dec 8, 2007 07:32 AM
A.S.I.M.O
Oct 4, 2006 02:52 PM
