misfire, rich, problem :Story
Old Mar 27, 2006 | 07:25 AM
90lshatch's Avatar
Default misfire, rich, problem :Story
Can anyone diagnose my problem. I have a 90civic hatch with a b18b motor. Okay so my battery dies late at night, didn’t think it alternator though it was battery terminal. Jiggle batter terminals alittle and get alittle juice. Okay when started engine runs rough misfire, smoke smell like gas, and wont rev over 4 thou rpm. Batter died because later I found out that my alternator ground was corroded and popped off. Put ground back on start it and is very rough misfiring, and wont go about 4 rpm. Any help would be appreciated cause im stumped.
Old Mar 27, 2006 | 04:28 PM
90lshatch's Avatar
Default Re: misfire, rich, problem :Story (90lshatch)
aight. well i check the timing it was off two teeth. Fixed: Problem was rock got into cam gears and messed up the timing belt.. The reason is was running so rich was because the aem bull crap regulator was JUNK. Aight now the problem is that under 3 thousand rpm car bogs under full load. But after 3 i can wot it. Also in neutral the engine revs up Normal..
ANy help would be helpfull
90lshatch's Avatar
o bough and installed new spark plugs and wires..
Old Mar 27, 2006 | 05:11 PM
Crx Jimmy's Avatar
do you know you can edit your posts so you dont have to post 3 times?
Old Mar 28, 2006 | 08:14 PM
ruffie_PL's Avatar
Default Re: misfire, rich, problem :Story (Crx Jimmy)
Check errors on ECU. Then check MAP and all vacuum lines.
MadTown
May 14, 2010 02:25 PM
JdmSpecTeggy
22
Oct 15, 2009 10:04 AM
stocker2shocker91
Mar 22, 2008 03:52 PM
ballerchild
13
Sep 22, 2006 08:04 AM
-DC2-
Aug 11, 2005 04:25 AM
