Transmission heads....
Old Apr 3, 2002 | 10:13 AM
drumsy's Avatar
New User
Default Transmission heads....
..what special tools do I need in order to rebuild one?
Old Apr 3, 2002 | 01:36 PM
Kataku2K3's Avatar
Default Re: Transmission heads.... (drumsy)
To take apart the casing i just use basic tools (12mm ratchet, a couple hex wrenches, and a little slothead screwdiver to pry the casing apart to break the Hondabond seal) They do make a special tool to release the spring clip that holds the countershaft but i just use a pair of needle nose pliers. Then on the stacks themselves there is no really big deal with those. With the differential however, if you replace it's bearings you will need a puller and a press. Unless you want to somehow pry them off with a crowbar then hit the new ones back on with a hammer. Anyways it really doesn't require a lot of tools to rebuild a tranny. Have fun!!!
fdavie
Aug 3, 2007 02:59 PM
b16ahybrid
Nov 26, 2005 06:42 PM
ECKOTYPER
Apr 9, 2004 08:26 PM
LsTurbo91
Jul 16, 2002 08:00 PM
