b18b question
hey i have a 91'LS integ and ive heard that its suppose to be a b18a motor but i have a b18b motor. so i was wondering what year integ this came off of because i know that the people that i bought this from had been replaced so yea. also i was wondering if the mounts for the b18b and the regular b18a are different?
b18bs are from 94+ integras and you can see the year of the mtoor by the 4 circle things on the head i think thier on ls heads also i know their on vtec heads
b18a, b18b, it's the same block. maybe the previous owner was having problems with the motor and instead of rebuilding it, replaced it with a more cost effective used LS block, which are a dime a dozen.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by manyakiexpi »</TD></TR><TR><TD CLASS="quote">so than i should be using the b18a motor mounts than? and theres should be no problem fitting those onto my car?</TD></TR></TABLE>
you use the mount that were meant for the car (90-91). does the engine say b18b1 or b18b? if it says b1 its a usdm 94-01 ls engine, if it says just b18b its a jdm ls engine...145hp and 127tq
yes you should use the b18a mounts, and they are the only ones that will fit on your car with a b-series motor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectTeG »</TD></TR><TR><TD CLASS="quote">
you use the mount that were meant for the car (90-91). does the engine say b18b1 or b18b? if it says b1 its a usdm 94-01 ls engine, if it says just b18b its a jdm ls engine...145hp and 127tq</TD></TR></TABLE>
yea it says b18b theres no 1 so than its jdm? but yea so cool so ima get the b18a1 mounts for my car than thanks guys!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by manyakiexpi »</TD></TR><TR><TD CLASS="quote">yea it says b18b theres no 1 so than its jdm? but yea so cool so ima get the b18a1 mounts for my car than thanks guys!
yea you get the mounts for the year of the car you have. i think the only difference between the 90-91 and the 92-93 mounts is the driverside mount.
and yes if it says b18b you have the jdm b18b with about 15 more hp and 6 more tq than the stock engine thats suppose to come in the 90-91 tegs.
</TD></TR></TABLE>yea you get the mounts for the year of the car you have. i think the only difference between the 90-91 and the 92-93 mounts is the driverside mount.
awesome!! but yea i looked at my girls integ because she has the 94 LS and i guess thats a b18b1? i assumed that the motor mounts on there where the ones i needed but they looked nothing like the ones that are on there already. her cars auto so iono if theres a difference in that.
