Block Decked, Timing Question
Old Mar 26, 2006 | 07:45 PM
TheYellowDart's Avatar
Default Block Decked, Timing Question
Ok my problem is that my b20vtec sounds like it is running on 3 cylinders. It is a fresh rebuild: cp pistons 11.5:1, eagle rods, stock headgasket, extrude hone b16 head, skunk2 pro1 cams and adj cam gears. What i am thinking is that since the block was decked .007 and the head i am not sure about, should i have to mess with my cam timing? Only cel is vtec pres. I am getting spark in all cylinders along with fuel. And my compression is good. Any ideas are welcome, but i am wondering if i would need to advance or retard my timing.
(i started a new thread due to bad thread title)
Old Mar 26, 2006 | 08:56 PM
Natural Aspirations's Avatar
Default Re: Block Decked, Timing Question (TheYellowDart)
.007 is nothing to worry about. general belief is .012 = 1 deg retarded. So at most you may wish to advance your timing .5 deg. Which isnt worth the trouble.
Old Mar 26, 2006 | 08:59 PM
anthony90si's Avatar
how much can you normaly deck a block?
Old Mar 27, 2006 | 05:16 AM
Depends on your pistons.
Old Mar 27, 2006 | 10:01 AM
Default Re: (crixzc)
ok so the car still runs like ***. i tried advancing both and i think it got worse, white smoke out the back like crazy. so i retarded both 1* and it did not smoke as bad bad, but who knows if that means anything. i was told by one guy to retard 3-4, and other people say advance1-2. has anyone had any 1st hand experiance? i found this info on the cams.
Intake
264 / 12.6 @ 1mm / 0.000” lash
Exhaust
264 / 11.9 @ 1mm / 0.000” lash
Clearance
Intake 0.007” cold
Exhaust 0.008” cold
Other recommended cam specs
Intake
24 degrees BTDC Opening
98 degrees ATDC Peak
50 degrees ABDC Closing
Exhaust
56 degrees BTDC Opening
105 degrees ATDC Peak
16 degrees ABDC Closing
101.5 Centerline
Old Mar 27, 2006 | 10:06 AM
Default Re: (TheYellowDart)
white smoke = BLOW HEAD GASKET
Old Mar 27, 2006 | 10:09 AM
On a side Note, you need to degree your cams. A guess will do nothing.
Old Mar 27, 2006 | 10:11 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crixzc &raquo;</TD></TR><TR><TD CLASS="quote">white smoke = BLOW HEAD GASKET </TD></TR></TABLE>
did compression and leak down tests, both are healthy as can be. the white smoke smells like straight gas. How do i degree the cams?
Old Mar 27, 2006 | 10:51 AM
b19coupe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheYellowDart &raquo;</TD></TR><TR><TD CLASS="quote">did compression and leak down tests, both are healthy as can be. the white smoke smells like straight gas.
Sounds like an engine management/tuning issue.
Old Mar 27, 2006 | 11:08 AM
Default Re: (b19coupe)
does anyone know of a good write up on cam degreeing?
Old Mar 27, 2006 | 05:39 PM
lohatch's Avatar
you running a PCV valve???
if not install one
if you run a straight hose from the back of the block to the IM it will smoke
Old Mar 27, 2006 | 05:44 PM
Default Re: (lohatch)
no. should i?
Old Mar 27, 2006 | 05:45 PM
lohatch's Avatar
just edited my above post.
if not install one
install a PCV and it will stop smoking and idle fine
Old Mar 27, 2006 | 05:48 PM
wait a second, where do i run the hose from?
Old Mar 27, 2006 | 05:51 PM
if i were running a catch can would that make it better?
Old Mar 27, 2006 | 07:04 PM
lohatch's Avatar
if you just ran a hose from the black box on the back of the block to the IM and didnt put a PCV valve inline your engine will smoke and idle irratic.
if you did this take the hose off you intake manifold and put your finger over the hole. car will probably idle right down and stop smoking like a bitch
Old Mar 27, 2006 | 07:15 PM
i though b20s did not have the black box on the back of the block
Old Mar 28, 2006 | 04:50 AM
lohatch's Avatar
ah **** youre right.
do you have any hoses running from the valve cover to the IM pulling out crankcase pressure??? look into it.
i had it happen on time, put a PCV valve inline and good to go
007EG
Dec 27, 2007 03:35 PM
TheYellowDart
Jun 14, 2006 07:47 AM
DJ Gurgla GSR
Nov 28, 2005 10:08 AM
Nextelbuddy
Mar 24, 2004 09:59 AM
