brakes lighting up dash lights?
Old Mar 26, 2006 | 03:21 PM
B18 rider's Avatar
Default Help!!! brakes lighting up dash lights?
I just finished putting my car together after doing a wire tuck and i found that when i press my brakes my dash lights, and all my center console lights come on.
does anyone know where/how the brake light circuit would come in contact with the dash light circuit?
thanks.
edit: it's a 94 LS
Modified by B18 rider at 1:33 AM 3/27/2006
Modified by B18 rider at 2:47 AM 3/27/2006
Modified by B18 rider at 10:29 PM 3/27/2006
Old Mar 26, 2006 | 03:28 PM
JThrasher79's Avatar
Default Re: brakes lighting up dash lights? (B18 rider)
mine was also doing this when i bought it. its wiring was all shady with the alarm fogs and sidemarkers. i striped everything and redid all of it. that didnt fix it, it turned out when i changed the tails from tinted black stock ones to 96' spec jdm tails it magically fixed it.. im not sure how but i can just say follow the break sensor wire and the headlight wire with a voltometer..?
Old Mar 26, 2006 | 05:46 PM
B18 rider's Avatar
I followed both lines and they dont look damaged anywhere, im not sure what to do. Im wondering if a should cut the lines at the break sensor and run a new one to the back, but I much rather figure out what is going on with it.
Old Mar 26, 2006 | 05:52 PM
Spectrum24x's Avatar
Default Re: (B18 rider)
Hmm, i know the brakelights are wired in with all these lights somehow b/c they are powered by the same fuse.
Maybe that can help you get a start to figuring it out.
goodluck
Old Mar 26, 2006 | 06:29 PM
B18 rider's Avatar
I dont think it has anything to do with the fuses
Old Mar 26, 2006 | 08:25 PM
92DAIntegraXSI's Avatar
Default Re: Help!!! brakes lighting up dash lights? (B18 rider)
brake light switch could of went bad ive seen this happen be4
Old Mar 27, 2006 | 11:31 AM
B18 rider's Avatar
but why would that light up the dash?
Old Mar 27, 2006 | 01:28 PM
B18 rider's Avatar
anybody else, I ran a new line to the break lights and it still does it, I dont understand how that can be..
Old Mar 27, 2006 | 02:16 PM
B18 rider's Avatar
nevermind people I found the problem, I was the light bulb.
b20accord
Jan 5, 2019 07:30 AM
Patrick Jordan
Aug 27, 2012 08:10 PM
Happy Gilmore
Mar 4, 2009 07:04 AM
TheJuggalo
Sep 3, 2002 12:35 PM
ControlNode
Audio / Security / Video
Mar 11, 2002 07:41 PM
