Complete Suspension Bushings
Hi guys,
thinking of replacing all the suspension bushings on my 1990 CRX si with b16a1, any suggestions to what I should use? Would u guys recommend stock oem parts for a daily driver? Also does anyone have a list of parts or suppliers they can recommend? I reside in Toronto, Ontario Canada.
thanks alot!
Sanj
thanks alot!
Sanj
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ruffie_PL »</TD></TR><TR><TD CLASS="quote">Go polyurethane!
Energy Suspension => http://www.energysuspension.co....html</TD></TR></TABLE>
x2
x2
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx Jimmy »</TD></TR><TR><TD CLASS="quote">stock or mugen</TD></TR></TABLE>
OEM.
look into buying the complete arm instead of individual bushings. buying a complete rear lower control arm is cheaper than the bushings alone.
i highly discourage the use of poly bushings.
Modified by Tyson at 2:54 PM 5/8/2006
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson »</TD></TR><TR><TD CLASS="quote">OEM.
Modified by Tyson at 2:54 PM 5/8/2006</TD></TR></TABLE>
Buying the individual bushings is actually cheaper than the whole arm by around $24bucks. But with the work involved to press the bushings out and then back in, I'd just spend the extra $ on the whole arm.
Ditto on the use of poly, expecially for a street car.
hmm yeah youre right. i must have figured the cost of having a brand new, freshly painted arm into it when i bought the complete arm.
52350-SH3-G11 ARM, R. RR. (LOWER) $69.48
52365-SH3-000 BUSH, RR. ARM (LOWER) (YAMASHITA) $14.58
52622-SH3-010 BUSH, RR. SHOCK ABSORBER (LOWER) $14.78 = $43.94
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson »</TD></TR><TR><TD CLASS="quote"> hmm yeah youre right. i must have figured the cost of having a brand new, freshly painted arm into it when i bought the complete arm.</TD></TR></TABLE>
Well don't forget about the cost of having someone press the bushings for you. The only local machine shop that I could find in the yellow pages charged me $10 each bushing. I found that route to be more cost effective when there were two or less in each arm (like front LCA). Rear LCAs, however, have 3 bushings each. That would cost $30 each LCA in press fees alone, so in that case I would much rather buy the whole arm new...
If I had a press in my garage, I'm sure I would do things differently...
Any of these options. OEM
</TD></TR></TABLE>Any of these options. OEM
