Which Harness is the OBD2 Plug-in port connected?
Old Mar 26, 2006 | 10:30 AM
JBirch_97Prelude's Avatar
Default Which Harness is the OBD2 Plug-in port connected?
I am converting my car back to OBD2 emissions and I can not buy a OBD2 plug-in port alone. Which Harness is connected to the Port, When I disconnected the plug-in from the bracket it was connected the Wiring went out the bottom of the car threw a hole behind the climate control, and stereo part of the dash. Near the Airbag module. Where does it go from there? By reading the Haynes Repair manual, only one wire goes to the (ECU), one to the fuse box, and one ground. Can I just cut it at the hole and make it excessible to emissions inspectors.
turbogsr18
Apr 21, 2008 08:27 PM
eJ6DM
Oct 10, 2006 07:12 PM
mchuang
Feb 2, 2006 01:33 PM
mportbusta
Aug 17, 2004 07:58 PM
lsvtec101
May 28, 2004 02:11 PM
