quick question about car maybe running to rich please help!!!
Old Mar 19, 2006 | 08:29 PM
xx89civicracer89xx's Avatar
Default quick question about car maybe running to rich please help!!!
Ok well i went to get my car smogged. 89 civic hatch Si with a SOHC ZC... well i have my fuel pres. turned to 44psi and had intake headers, and uderdrive pully and timing was stock... well i just got a pre test and it passed with flying colors.. so then i went about a week later with my car all stock and got it tested and failed for high HC and CO.. well i think its because i took off my fuel regulator... im thinking that my car might be running to rich right now so if i turn my fuel pres. back to 44 instead of the stock 34 i belive do u think i should pass>?
i was just wondering does turning your fuel pres. up make ur car run richer or leaner>? please HELP!!!
Old Mar 20, 2006 | 01:24 PM
Default Re: quick question about car maybe running to rich please help!!! (xx89civicracer89xx)
BUMP! please someone help i need to get my car smogged
Old Mar 22, 2006 | 02:43 PM
D_CRX_Si's Avatar
Also a lil curious.?
Old Mar 22, 2006 | 06:58 PM
Default Re: quick question about car maybe running to rich please help!!! (D_CRX_Si)
ya its wierd because high CO means its not buring all the fuel... and when my pressure was turned up it passed then when i turned it back down it failed... well i just threw my regulator back on and turned the pres. back up and im a just get a pre test done on it tom. so ill post my results
Old Mar 23, 2006 | 09:20 AM
thesmogman's Avatar
Here is a little info..
You are looking at a lean misfire. Less pressure equals less gas.
When your car misfires that raises the CO because of incomplete combustion. It will also raise the HC's too.
For a ZC I show a fuel pressure of 40 - 47 psi for a 1590cc w/inj 1992 - 95
For a 1996 - 00 the f pressure should be 38 - 46 psi
I would think that is it, fuel pressure...
Old Mar 24, 2006 | 09:42 AM
Default Re: quick question about car maybe running to rich please help!!! (thesmogman)
alright thanks a lot... i turned my pres. to 42 yesterday, and im trying to get a pre test done but they dont have anytime, so im a try calling them again today...
Old Mar 24, 2006 | 05:15 PM
well went to get it smogged and it failed again and for HC and CO so now im a just pay for smog
Old Mar 26, 2006 | 10:44 AM
well i passed smog yesterday (a pre-test) now i have to go to a test only place and get it tested... all i did was turn my fuel pressure down to 30psi(car ran like ****) but it passed with FLYING colors..
xx89civicracer89xx
May 23, 2006 07:01 PM
boosted_zc
Apr 22, 2004 01:21 PM
