Which Gauges for a Turbo R?
Old Apr 3, 2002 | 07:27 AM
ZygSpeed's Avatar
Default Which Gauges for a Turbo R?
None will be mounted on the pillar!!
Hondata datalogging will be in effect (hopefully eurodeseo sells me his Vaio soon).
In addition to the J&S dual monitor and boost.
Out to lunch, back after Pad Thai and a short quick run of the R ... ed
Old Apr 3, 2002 | 07:43 AM
Type-ARR's Avatar
Default Re: Which Gauges for a Turbo R? (Zygspeed)
boost.....you dont really "need" any other gauge, but get a EGT if you want two.
Old Apr 3, 2002 | 07:45 AM
People_Mover's Avatar
From: HT PRO POKER PLAYER IM FOR FREE STARTUP, MONEY
Default Re: Which Gauges for a Turbo R? (TurboR481)
yeah, a boost one would be helpful
Old Apr 3, 2002 | 07:54 AM
Batoutahell's Avatar
In addition to boost and egt, I would recommend a temperature gauge because your block will run hotter than normal under boost, especially on the track. The OEM temp gauge is not all that accurate.
Old Apr 3, 2002 | 08:12 AM
Austin's Avatar
Default Re: Which Gauges for a Turbo R? (Batoutahell)
How about these Ed...
1. Oil Temperature
2. EGT
3. Fuel Pressure
4. Boost
5. Oil Pressure
6. H2O temp(maybe)(although you could always wire in a thermo based switch to turn on a light when you exceed X degrees since you have datalogging and will be able to see what the temps were after the run)
Austin
Old Apr 3, 2002 | 08:14 AM
austrian type-R's Avatar
Default Re: Which Gauges for a Turbo R? (Austin)
I have an oilcooler with thermostat and a JR coolant thermo for lower engine temp.
I have
oil temp
oil press
fuel press
EGT temp
boost gauge by GREDDY!!!!!!!!
GAUGES OWNZ j00
Old Apr 3, 2002 | 09:28 AM
ZygSpeed's Avatar
Default Re: Which Gauges for a Turbo R? (austrian type-R)
Thanks Guys!
I'm thinking of sticking most of them under the radio, but maybe also a couple important ones up/by/instead of the clock.
Ahh.. fuel pressure...
What temp is the mark before half (or at 1/2, e.g., straight up) on the stock water temp gauge?
[Modified by Zygspeed, 1:29 PM 4/3/2002]
Old Apr 3, 2002 | 10:29 AM
Mike K's Avatar
Screw gauges. They are over rated.
Don't even rock a cluster. Sell it and get a cluster blocker plate.
Dat chit is ill.
Old Apr 3, 2002 | 10:31 AM
PM-Performance's Avatar
Default Re: Which Gauges for a Turbo R? (Mike K)
hahaha, that sounds pretty ill
Old Apr 3, 2002 | 11:01 AM
ZygSpeed's Avatar
Screw gauges. Sell it and get a cluster blocker plate.
Dat chit is ill.
Maybe I can mount a few up/out on the hood, and run the lines/wires up through the squirters!
J&S dual monitor, boost, oil temp and pressure and an EGT.
Sorry Mike, I'm an info junkie but a full set of STACK w/the cluster blocker is not in the cards at the moment. hehe
Old Apr 3, 2002 | 11:05 AM
b00st-0wnz's Avatar
From: Drinking Beer in sunny FL and jamming to Skid Row, USA
Dat chit is ill.
1. Fuel Press in the engine bay
2. Oil Temp
3. Oil Press
4. Water Temp
5. Boost/Vacuum
6. EGT (sender in downpipe)
7. Water Sprayer Resovior Low light
8. Water Sprayer Switch
9 VTEC light y0!
Old Apr 3, 2002 | 11:14 AM
Willard's Avatar
Turbine "revolution counter" would be nicey nice.
Will
Old Apr 3, 2002 | 11:17 AM
ZygSpeed's Avatar
Default Re: Which Gauges for a Turbo R? (Willard)
Will
CooL ... guess that will be the doppler effect one!
hehe ... a "snail tach"
Old Apr 3, 2002 | 11:27 AM
AssPenny's Avatar
Don't forget those usefull a/f meters... maybe and inside and outside air temp gauge. Also what about an air speed gauge. Don't forget to get something that will monitor the welds on your intake manafold, you might need a laptop to tell u that though
Old Apr 3, 2002 | 11:31 AM
Austin's Avatar
Will
You know what...I'd think that was pretty funny, except I know that they actually make one, although it's actually a rpm gauge for the turbine.
Old Apr 3, 2002 | 11:41 AM
ZygSpeed's Avatar
Exactly... I used to examine some measuring and testing applications in years past!
But wouldn't it be better to mount the EGT in the Exahust manifold close to the exhaust pott, and before the turbine (for most accurate results. Other than that you've got to "guestimate" about a 300degree F drop.
P.S. my friend with the Peter Farrell mods on his FD3 has sensors before and after his intercooler!
[Modified by Zygspeed, 3:42 PM 4/3/2002]
Old Apr 3, 2002 | 11:42 AM
Willard's Avatar
That is why I suggested it.
Old Apr 3, 2002 | 11:43 AM
MUGENTYPER's Avatar
if u dont mind me askin, what type of turbo set-up do u have on your R?
Old Apr 3, 2002 | 11:46 AM
Johnny Tran's Avatar
mount egt sender approx 2" off the header flange
Old Apr 3, 2002 | 11:47 AM
ZygSpeed's Avatar
Default Re: Which Gauges for a Turbo R? (MUGENTYPER)
Drag III kit running Hondata, 3 bar map, high flow pump, bigger injectors, ... 9:! pistons/rods/sleeved block.
Sorry but I'm not familiar with the REV HARD stage 2C kit, but overall I like the quality of their hardware.
Old Apr 3, 2002 | 12:11 PM
Willard's Avatar
http://www.omori-na.com/catalog/spec...turbinerpm.htm
NICEY NICE!
Will
1DayIllBFast
May 9, 2009 11:25 PM
BUBBLE BOY
Sep 23, 2006 09:46 AM
ninja8oi
Dec 14, 2003 05:10 PM
RacerBoy
Feb 5, 2003 08:55 AM
integra-modder
Jul 21, 2002 05:03 PM
