recommended gauges for turbo? and boost controller?
Old May 7, 2009 | 11:38 PM
1DayIllBFast's Avatar
Default recommended gauges for turbo? and boost controller?
what are the recommended gauges for a turboed civic? also what are your opinions on manual boost controllers?
Old May 8, 2009 | 01:22 AM
teg racer 877's Avatar
Default Re: recommended gauges for turbo? and boost controller?
guages are guages.. just get what looks cool to you, (auto meter, defi) no autozone crap tho...
many people say the simple no name/knockoff mbc's on ebay work great.
Old May 8, 2009 | 04:26 AM
Whatever's Avatar
I think he means what type of gauges, not what brand. I'm kind of curious myself... I've gotten a Boost gauge and a Oil Temp gauge (VDO) so far, but am wondering what else I should get.
Old May 8, 2009 | 04:30 AM
patrickd_21's Avatar
^in that case as many as it takes to make you feel confident that your setup is working well.
bare minimum is a boost gauge and an oil pressure gauge. Also highly recomended is a Wideband to keep an eye on your air/fuel ratios. After that you can start getting into things such as oil temp, water temp which are usefull.
In my setup i was running just a Inovate LC-1 wideband, Autometer boost gauge, and an autometer oil pressure gauge for the last 2 summers
I just bought a water temp and oil temp gauge cause i do alot of lapping and ive been having some overheating problems that i wanna fix
Old May 8, 2009 | 04:33 AM
90civichbsi's Avatar
what kind of engine management are you running? With neptune RTP or hondata s300 You can get a pwm boost solenoid relatively cheap and control boost by gear.
as for gauges I personally run boost, water temp and exhaust temp. On my last setup I had an oil pressure gauge but this time around I didnt think I needed it.
Old May 8, 2009 | 06:03 AM
redlinetuning's Avatar
I'm running an oil temp, oil pressure(bar), boost (bar), EGT, (all Autometer) and wideband with the S300. I thought about getting the TunerVisionII, but I actually like having everything there, without having to scroll through a screen like on the TunerVisionII.
Old May 8, 2009 | 09:55 AM
I have/ getting the S300. And yes i was talking about what kind not what brand. I never thought about getting the pwm boost with the s300. but i do not want my car to be gauged out so i just want the necessary ones.
Old May 8, 2009 | 10:00 AM
what ever you feel is necessary for your needs... Everyone has different needs. What's important to some may not be for you. I'm ****, that's why I have 5 different guages. i don't care if it's guaged out or not, or what other people think about the guages. It's about what I need to know about my engine, not what other people think.
Old May 8, 2009 | 10:01 AM
if you only want one central unit instead of alot of gauges you could get the tuner vision and a wideband 02 like someone else stated. you dont really have to scroll through anything to see all the readings it has the option to show most if not all. I dont have it personally but i have seen it on other cars and its nice.
Old May 8, 2009 | 08:16 PM
Slosc2's Avatar
I rock a boost gauge and a wideband.
Old May 8, 2009 | 08:33 PM
nfereorhatch's Avatar
Me to.
Old May 9, 2009 | 07:02 AM
DA TeG 90's Avatar
Auto meter Boost, Oil Pressure and AEM Wideband.
Old May 9, 2009 | 07:09 AM
Hobkins's Avatar
Just get what *you* feel neccessary, I picked boost, oil press, egt. Possibly adding wideband later.
Old May 9, 2009 | 07:11 AM
DA TeG 90's Avatar
Wideband FTW
Old May 9, 2009 | 07:51 AM
jasoncrashtech's Avatar
wideband , boost gauge .
Old May 9, 2009 | 07:54 AM
HamiltonRex's Avatar
water temp/ oil pressure/ boost/ egt/ wb02/ aem serial gauge.
Old May 9, 2009 | 09:33 AM
megomaniac's Avatar
If you go plx, you can display multiple senors on one gauge. I have a plx wideband and egt, that will be displayed on one gauge other than that I plan on getting a oil pressure, maybe some temp gauges later.
Old May 9, 2009 | 09:51 AM
miro_gt's Avatar
boost + wideband
other than those two, monitor whatever you want
Old May 9, 2009 | 09:53 AM
omiehomie's Avatar
stack gauges have been the best bang for my buck, and they are very low key
http://www.stackltd.com/instruments.html
i would personally run a oil pressure, EGT (exhaust gas temp), and a Wide-band A/F(Lambda) Gauge to tell you if your running lean or rich...
hope that helps
[img]http://www.stackltd.com/analog_gauges_web/ST3401.gif[img]
Old May 9, 2009 | 12:07 PM
Whatever's Avatar
I just ordered an Innovate wideband AFR gauge for a great price. I'm glad I came into this thread...
Old May 9, 2009 | 12:54 PM
rustydusty1717's Avatar
Boost, Oil pressure and wideband. You really don't need EGT and water pressure, they are not a priority. I run an EGT on my diesel, but that's cause it's very important to keep an eye on exhaust temp's on a diesel.
Old May 9, 2009 | 03:53 PM
Got traction's Avatar
oil pressure and boost for me
Old May 9, 2009 | 11:25 PM
Boost and oil pressure are the most important to have. If you can afford a wideband, I'd do it to. It's a good idea to be keeping an eye on your A/F to, just incase something happens with the tune.
MooreBoost
Apr 14, 2009 04:39 AM
BUBBLE BOY
Sep 23, 2006 09:46 AM
jdm.ej
May 20, 2004 05:16 AM
ninja8oi
Dec 14, 2003 05:10 PM
Goldfingiz
Jul 21, 2003 04:26 AM
