99 H22 in 94 Prelude Si, any problems to look for?
Old Apr 3, 2002 | 07:17 AM
Finest's Avatar
Default 99 H22 in 94 Prelude Si, any problems to look for?
Is there anything that I should look out for? I'll be using an OBD-I ECU. What do I have to switch/change to get the 99 H22 working in an OBD-I chassis? I'm assuming the distributor, VTEC wires, and knock sensor....anything else?
Old Apr 3, 2002 | 09:43 AM
Finest's Avatar
Default Re: 99 H22 in 94 Prelude Si, any problems to look for? (Prelude_RCR)
TTT.
Old Apr 3, 2002 | 05:43 PM
Finest's Avatar
TTT again....
Old Apr 5, 2002 | 05:39 AM
Finest's Avatar
There's gotta be some Si guys with H22 swaps in here?!!
Old Apr 5, 2002 | 11:07 AM
PrecisionH23a's Avatar
the h22a motor should be a direct bolt on to your car. as far as OBD1 and OBD2, i believe skunk2 makes a wiring harness that will convert yours from a 1 to 2. and yes, you will need the distributor, knock sensor, axles (unless the h23a and h22a ones are the same, im not sure), wire harness, h22a ECU,
Old Apr 6, 2002 | 02:16 PM
Finest's Avatar
Default Re: 99 H22 in 94 Prelude Si, any problems to look for? (GudeH23a)
Well, I don't want to run OBD-II. As far as electronics go, I'm assuming the extra O2 sensor and distributor will be the main concerns when switching back to OBD-I. Is there anything else that I need to switch back to OBD-I? That's my biggest concern...thanx!
Old Apr 7, 2002 | 06:48 PM
ELUD THS's Avatar
New User
post on here how it turns out, my friend was thinking of the same swap AND converting obd sensors over as well.
raider5963
Nov 9, 2017 11:20 AM
tanner_pimp101
Apr 1, 2014 08:11 PM
Speedfiend97LX
Jun 2, 2011 12:41 PM
sohclude
Feb 23, 2009 03:12 PM
92gsrhatch
Dec 21, 2003 04:18 PM
