Honda S2000 Honda S2000
oil drain bolt gasket
Old Mar 26, 2006 | 06:44 AM
mellowhead's Avatar
Default oil drain bolt gasket
Is there any place that sells the gasket except for Honda. I would love to change my oil, but NO one in town(JAx, FL) carries the gasket in stock. This is crazy!!! I tried Advanced, pepboys, autozone. I am looking for the nicer ones....brass w/rubber seal, not the plactic crush ones. Does any one carry these in stock?
Old Mar 26, 2006 | 07:00 AM
Sideways's Avatar
Default Re: oil drain bolt gasket (mellowhead)
The factory uses an aluminum crush washer. You can reuse the old one, just turn it over. Get some in advance for the next time.
Old Mar 26, 2006 | 08:23 AM
juniorreds's Avatar
Yah the dealerships here in kansas always supply a crush washer for free when you purchase an oil filter. And like sideways said it's an aluminum crush washer.
Old Mar 26, 2006 | 08:38 AM
mellowhead's Avatar
Default Re: oil drain bolt gasket (Sideways)
Do you know the size of the drain bolt....I found one of my old brass/rubber gaskets for my old accord. It's a 1/2inch. wondering if this will fit? I don't want to reuse a crush washer. If not I will wait til Monday to go to Honda.
Thanks
Old Apr 27, 2006 | 05:22 PM
tekstyle's Avatar
Default Re: (juniorreds)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by juniorreds &raquo;</TD></TR><TR><TD CLASS="quote">Yah the dealerships here in kansas always supply a crush washer for free when you purchase an oil filter. And like sideways said it's an aluminum crush washer.</TD></TR></TABLE>
really? i went to my local dealer and they gave me 2 opinions, filter only, or filter plus aluminum washer for 35 cent extra.
Old Apr 27, 2006 | 06:21 PM
Mr. Projekt's Avatar
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mellowhead &raquo;</TD></TR><TR><TD CLASS="quote">Is there any place that sells the gasket except for Honda. I would love to change my oil, but NO one in town(JAx, FL) carries the gasket in stock. This is crazy!!! I tried Advanced, pepboys, autozone. I am looking for the nicer ones....brass w/rubber seal, not the plactic crush ones. Does any one carry these in stock? </TD></TR></TABLE>
Plastic? Don't even think about it. I think the thread is 12x1.25, look for crush washers that would fit that bolt.
Old Apr 27, 2006 | 07:19 PM
Francesco's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mellowhead &raquo;</TD></TR><TR><TD CLASS="quote">Do you know the size of the drain bolt....I found one of my old brass/rubber gaskets for my old accord. It's a 1/2inch. wondering if this will fit? I don't want to reuse a crush washer. If not I will wait til Monday to go to Honda.
Thanks</TD></TR></TABLE>
17mm drain bolt.
Old Apr 28, 2006 | 09:46 AM
mellowhead's Avatar
Default Re: (tekstyle)
You are correct. The guy at the counter told me that sometimes people think they are free because they tape it to the filter so you don't lose it. He said check your receipt...they should have charged for it.
Old Apr 28, 2006 | 09:47 AM
mellowhead's Avatar
Default Re: oil drain bolt gasket (FR-MOB: Projekt)
No way would I do plastic.......not even in my accord would I use plastic
Old Apr 28, 2006 | 09:48 AM
mellowhead's Avatar
Default Re: oil drain bolt gasket (Francesco)
Yep it was the same as my accord...I did end up going to Honda and bought twenty of their al. crush washers
Old Apr 28, 2006 | 11:59 AM
iam7head's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sideways &raquo;</TD></TR><TR><TD CLASS="quote">The factory uses an aluminum crush washer. You can reuse the old one, just turn it over. Get some in advance for the next time.</TD></TR></TABLE>
please dont turn it over, the softer side needs to be facing the oilpan
sauterindy
Honda CR-V & Element
Jan 23, 2016 08:31 PM
sma_V6
Jan 17, 2011 01:22 PM
gjoey66
Jan 24, 2008 01:24 PM
perseverance
25
Dec 9, 2006 03:55 PM
OpTiX619
Feb 4, 2004 07:48 PM
