need a little bit of help regarding short wire
Old Mar 26, 2006 | 03:08 AM
andrew714's Avatar
Default need a little bit of help regarding short wire
i am in the process of wiring my jdm headlights and i put both of the Green constant (green with blue line) and the sidemarker wire(green with white line) to one bulb and it blinked very fast for about 5 seconds and then went out. it also made the left turn signal on the cluster go on as well. i shouldn't have done this because now i have just shorten the green white wire and i dont know where to start to repair this wire. i know it is fubar because it wont power anything. plz help if you can understand what is happening. thank you ht members.
Old Mar 26, 2006 | 06:50 AM
rkrone's Avatar
Default Re: need a little bit of help regarding short wire (andrew714)
first, get a wiring diagram, u can get a manual in pdf at hondahookup.com
then, take out the bulb, and test the wires individually
a voltmeter would be helpful for this, also check the wires that go to the hazard flashers button, becuase the signal goes through this to complete circuit
Old Mar 26, 2006 | 08:01 AM
andrew714's Avatar
Default Re: need a little bit of help regarding short wire (rkrone)
i already done with the wiring, it is just while in the process i shorted one wire and now i want to go back and redo that wire.
6KAOS6
26
Feb 19, 2011 07:22 PM
poppycock2
Mar 16, 2004 04:45 PM
type r 01-1063
Dec 13, 2003 06:08 PM
