get into mid rpm range...bog down. problem???
Old Mar 26, 2006 | 01:20 AM
bumbaiulearn's Avatar
Default turbo mid rpm range...bog down. problem???
any ideas of what the problem might be?
I've got a 99 civic with a built d16z6 motor running turbo. tuned with neptune for 15 psi. just to give you background, a couple months ago i had this similar problem. when i accelerate, the car would hit mid rpm range and then just bog down really bad. someone told me that i might have fouled spark plugs and when i changed the plugs the problem was gone and my car ran fine and strong. the brand of plugs i used were denso.
then just last night i went to the track and put in some new plugs but this time i used ngk plugs because no automotive store around here sold denso. on my second run down the track i had the same problem occur...mid rpm...bog down. but this time when i replaced the plugs with a new set, the problem is still there.
is this because i use a different brand of plugs and i should stick with denso? or what else could the problem be? thanks for any help
Old Mar 26, 2006 | 03:05 AM
ondahush's Avatar
i highly doubt that its your plugs my friend was having the same problem when he hit about 5krpm he would bog down too but his set up was a b16a turbo and found out it was his distributer
Old Mar 26, 2006 | 06:54 PM
Default Re:
bump for more help
Old Mar 26, 2006 | 07:56 PM
Default Re:
help pleeeaaaaasse
Old Mar 27, 2006 | 12:32 PM
nobody has any idea??
Old Mar 27, 2006 | 12:52 PM
JDM_CivicEG6's Avatar
Default Re: (bumbaiulearn)
Your car has VTEC right?
Old Mar 27, 2006 | 06:50 PM
Default Re: (JDM_CivicEG6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_CivicEG6 &raquo;</TD></TR><TR><TD CLASS="quote">Your car has VTEC right?</TD></TR></TABLE>
yes it does but i'm not sure if it's hooked up or even working.
Old Mar 27, 2006 | 07:31 PM
4dohs4mohoes's Avatar
If it was a bad plug the problem would occur through all rpm ranges.
What fuel sys. are you running?: injectors, FMU, regulator.
It could be bad A/F mixtures at that RPM. Try lowering the boost and see if it still happens.
Old Mar 27, 2006 | 07:33 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bumbaiulearn &raquo;</TD></TR><TR><TD CLASS="quote">
yes it does but i'm not sure if it's hooked up or even working.</TD></TR></TABLE>
AND HOW THE expletive CAN YOU HAVE A FULLY BUILT HONDA, AND NOT KOW IF VTEC IS WORKING?!?!
Idiot
Old Mar 28, 2006 | 12:39 AM
Default Re: (boo bees)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boo bees &raquo;</TD></TR><TR><TD CLASS="quote">
Idiot </TD></TR></TABLE>
well, for the smart guy...before this car, i've never driven a car w/VTEC before. before the swap, it was just a stock dx. second, can you REALLY tell w/SOHC vtec when it kicks in??? i don't know, maybe. when I built and swapped the motor I put on the turbo at the same time. and after that, seems like the turbo spools up around the same time vtec is supposed to kick in.
turbo pulls harder than VTEC
Old Mar 28, 2006 | 12:43 AM
What fuel sys. are you running?: injectors, FMU, regulator. </TD></TR></TABLE>
RC 550cc injectors, walbro fuel pump, and neptuned.
Old Mar 28, 2006 | 12:49 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boo bees &raquo;</TD></TR><TR><TD CLASS="quote">If it was a bad plug the problem would occur through all rpm ranges.
It could be bad A/F mixtures at that RPM. Try lowering the boost and see if it still happens.</TD></TR></TABLE>
Why did the problem go away after I changed the plugs before? if the problem is NOT the plugs, then even after changing the plugs, my car should still bog down, right?
jdm.fanatic
Sep 26, 2009 05:14 AM
bambbrose
Nov 9, 2008 09:56 AM
kgibson16
Dec 4, 2005 10:56 AM
boosted lude
Oct 10, 2004 12:23 PM
1dumbscreenname
Jul 17, 2003 01:15 PM
