VSS affect performance in GSR???
Old Mar 25, 2006 | 07:33 PM
geezer_187's Avatar
Default VSS affect performance in GSR???
I was wondering if an inop VSS will hurt your performance. Mine is inop and I have no speedo w/ a CEL. It feels like its not running the same, and I didnt know if it was just me. Any input would be appreciated, thanks.
Old Mar 25, 2006 | 07:36 PM
98IntegraLSNonVtec's Avatar
Default Re: VSS affect performance in GSR??? (geezer_187)
My ls has a non-running VSS and it seems good...only thing is I now no longer know how many miles I have put on my car
Old Mar 25, 2006 | 08:11 PM
geezer_187's Avatar
Default Re: VSS affect performance in GSR??? (98IntegraLSNonVtec)
I wasnt sure if the ECU used that sensor for timing advance or anything important of that sort. It just feels like my car has run crappy since the CEL came on for it after i broke it.
Old Mar 25, 2006 | 08:20 PM
I don't believe the speed is used for the timing..considering the timing is set at idle..make sure that the cam gears both match the same direction..
Old Mar 25, 2006 | 11:18 PM
2SlowDC's Avatar
ure vtec wont work without a properly working vss.
Old Mar 26, 2006 | 12:19 AM
Default Re: (No-Tec)
well..vtec engages according to the rpms and not the speed so it should still engage...my VSS does not work and the tach. still functions.
Old Mar 26, 2006 | 05:28 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: (98IntegraLSNonVtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98IntegraLSNonVtec &raquo;</TD></TR><TR><TD CLASS="quote">well..vtec engages according to the rpms and not the speed so it should still engage...my VSS does not work and the tach. still functions.</TD></TR></TABLE>
Everything that I have read, says that a minimum speed must be reached before the VTEC system will engage. The VSS is needed for this.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by geezer_187 &raquo;</TD></TR><TR><TD CLASS="quote">I was wondering if an inop VSS will hurt your performance. Mine is inop and I have no speedo w/ a CEL. It feels like its not running the same, and I didnt know if it was just me. Any input would be appreciated, thanks.</TD></TR></TABLE>
What CEL is stored?
https://honda-tech.com/zerothread?id=978933
Old Mar 26, 2006 | 05:30 AM
teggy182's Avatar
Default Re: (Dogginator)
vtec is engadged by oil pressure
Old Mar 26, 2006 | 05:36 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: (teggy182)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teggy182 &raquo;</TD></TR><TR><TD CLASS="quote">vtec is engadged by oil pressure</TD></TR></TABLE>
Yes, and the ECU sends a signal to the VTEC solenoid to allow this oil pressure to reach the rockers. The VTEC will not function without the VSS with a stock ECU.
Old Mar 26, 2006 | 06:13 AM
geezer_187's Avatar
Thank you for all of your input. To be honest, it feels as though my high rpm's are very sluggish, but the sound of the butterflies in the intake opening made me think I was crazy, considering I couldnt hear vtec engage in the first place, but I guess if its not engaging it would explain why my car is running like butt.
Old Mar 26, 2006 | 06:25 AM
SupaFly_Honda's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator &raquo;</TD></TR><TR><TD CLASS="quote">Yes, and the ECU sends a signal to the VTEC solenoid to allow this oil pressure to reach the rockers. The VTEC will not function without the VSS with a stock ECU.</TD></TR></TABLE>
this is correct
Old Mar 26, 2006 | 01:04 PM
geezer_187's Avatar
Default Re: (SupaFly_Honda)
Thank you guys, any other input?
Old Mar 26, 2006 | 01:22 PM
Shaun's Avatar
Default Re: (geezer_187)
Dogginator is right!!! with everything he said
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by geezer_187 &raquo;</TD></TR><TR><TD CLASS="quote">Thank you for all of your input. To be honest, it feels as though my high rpm's are very sluggish, but the sound of the butterflies in the intake opening made me think I was crazy, considering I couldnt hear vtec engage in the first place, but I guess if its not engaging it would explain why my car is running like butt.</TD></TR></TABLE>
yeah you have no vtec buddy... fix the VSS like dogginator said earlier!
Old Mar 26, 2006 | 01:23 PM
Shaun's Avatar
yeah.. I can tell you drive an LS..
Old Mar 26, 2006 | 04:03 PM
freakasis's Avatar
ok this is all the true stuff....
vtec will only kick "IF and ONLY IF":
speed is at least 20 mph (based on vss imput)
oil pressure is X amount
rpms are X amount
and throttle is at X amount
no vss no vtec
oil oil pressure sensor no vtec
no position sesor(for the rpms) no vtec
and finally no tps no vtec
the butterflys are not based on speed they are based on rpms only so you should still hear those around 6k i think.
Old Mar 26, 2006 | 05:46 PM
gsr dood's Avatar
Default Re: (freakasis)
my VSS was off for a while and i DEF had Vtec.
Old Mar 26, 2006 | 06:21 PM
LSvtec03's Avatar
oil pressure is only one of the conditions that must be met in order for vtec to operate.
rpm, speed, the car being in gear (not neutral), and engine temp are all factors.
Old Mar 28, 2006 | 03:25 PM
geezer_187's Avatar
Default Re: (LSvtec03)
Installed my new VSS. Finally have a speedometer, and my vtec is finally engaging. Its been about 6 months since I've had it, and I almost forgot what it was like! Thank everyone who gave me the right info, I owe ya one!
Old Mar 28, 2006 | 08:05 PM
K.Quinn's Avatar
indeed mad vtec was hit. cant wait till i get my c1 head.
Redness44
Sep 30, 2008 07:36 PM
davidcrx89
Aug 17, 2008 10:54 PM
CiviC RacecaR
Jun 21, 2005 03:46 AM
deftones0817
Oct 18, 2004 11:38 AM
DumpedSi
Sep 10, 2003 04:57 PM
