b18c and b18c1....searched
Old Mar 25, 2006 | 04:41 PM
-_My92DA_-'s Avatar
Default b18c and b18c1....searched
I bought a honda motor swap book to do some homework. In the back of the book it has all of the engine codes and what not. The b18c is listed as JDM and the b18c1 is listed as USDM. I see on here that people have there engines listed as a JDM b18c1 is this incorrect? Or does the book have the wrong information?
Old Mar 25, 2006 | 04:51 PM
RaceMyGhost's Avatar
Default Re: b18c and b18c1....searched (-_My92DA_-)
the b18c1 is the USDM GSR engine. the b18c i believe is the ITR motor in JAPAN (not to sure, someone verify this)
Old Mar 25, 2006 | 04:53 PM
..::91TEG-G2::..'s Avatar
Default Re: b18c and b18c1....searched (RaceMyGhost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RaceMyGhost &raquo;</TD></TR><TR><TD CLASS="quote">the b18c1 is the USDM GSR engine. the b18c i believe is the ITR motor in JAPAN (not to sure, someone verify this)</TD></TR></TABLE>
hmm, not too sure, if i remember correctly, USDM is b18c1, JDM is b18c and so is the ITR.. but of course performance of the engine is different.. dont quote me on this and i probably will stand corrected.. and of course, USDM ITR - b18c5
Old Mar 25, 2006 | 04:54 PM
GSRdude's Avatar
Im not sure if the b18c is ITR or not, but it is def. JDM
Old Mar 25, 2006 | 04:55 PM
GSRdude's Avatar
Default Re: b18c and b18c1....searched (GSRdude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ..::91TEG-G2::.. &raquo;</TD></TR><TR><TD CLASS="quote">
hmm, not too sure, if i remember correctly, USDM is b18c1, JDM is b18c and so is the ITR.. but of course performance of the engine is different.. dont quote me on this and i probably will stand corrected.. and of course, USDM ITR - b18c5 </TD></TR></TABLE>
Old Mar 25, 2006 | 05:15 PM
Nighthawk R18's Avatar
yes the B18c is the japanese type-R.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -_My92DA_- &raquo;</TD></TR><TR><TD CLASS="quote">I bought a honda motor swap book to do some homework. In the back of the book it has all of the engine codes and what not. The b18c is listed as JDM and the b18c1 is listed as USDM. I see on here that people have there engines listed as a JDM b18c1 is this incorrect? Or does the book have the wrong information?</TD></TR></TABLE>
where'd you get that book?
Old Mar 25, 2006 | 05:45 PM
boostedsc61's Avatar
Default Re: b18c and b18c1....searched (VTEC Genetics)
the b18c is also a jdm gsr
Old Mar 25, 2006 | 07:51 PM
Promina's Avatar
According to Spoon Sport's Tatsuru Ichishima, The B18C stamps means it could be a C2 or C3. C1 through C3 of the VTEC B Series are considered the knock-down models in Japan. The favored engines are the B18C4s, which are not available in the US. This was out the 2002 August issue of Import Tuner that I have.
Old Mar 25, 2006 | 08:47 PM
jtracing919's Avatar
i have a obd1 jdm gsr (sir) motor and it is stamped with b18c. I'm pretty sure that they are identical except jdm version has a little higher compression and doesn't have evap. stuff on it.
Old Mar 26, 2006 | 06:45 AM
-_My92DA_-'s Avatar
Default Re: b18c and b18c1....searched (jtracing919)
So my question is when people say they have a JDM b18c1, they really dont because it doesn't exist?<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTEC Genetics &raquo;</TD></TR><TR><TD CLASS="quote">where'd you get that book?</TD></TR></TABLE>
I bought it at Barnes and Nobles. It has some helpful information for the people that havent tackled the project before.
Old Mar 26, 2006 | 07:34 AM
thanks.
Old Mar 26, 2006 | 08:06 AM
mike9571's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -_My92DA_- &raquo;</TD></TR><TR><TD CLASS="quote">So my question is when people say they have a JDM b18c1, they really dont because it doesn't exist? </TD></TR></TABLE>
Thats correct theres no JDM b18C1. The people that say that are just jumping on the JDM bandwagon
Old Mar 26, 2006 | 08:42 AM
JDMilanoRed's Avatar
Default Re: b18c and b18c1....searched (mike9571)
b18c is JDM only.. but it is not just ITR... it's also sir-g... both are stamped 'b18c'
Old Mar 26, 2006 | 09:31 AM
mugenracer's Avatar
Default Re: (Promina)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Promina &raquo;</TD></TR><TR><TD CLASS="quote">According to Spoon Sport's Tatsuru Ichishima, The B18C stamps means it could be a C2 or C3. C1 through C3 of the VTEC B Series are considered the knock-down models in Japan. The favored engines are the B18C4s, which are not available in the US. This was out the 2002 August issue of Import Tuner that I have.
There is no such thing as a B18C2.
B18C = JDM Integra Si/SiR/SiR-G and JDM ITR (96 and 98spec)
B18C1 = US GSR
B18C3 = Aus/NZ Integra VTi (same as US GSR-Dual Runner IM)
B18C4 = UK Civic VTi
The B18C4 is the same engine as the US GSR (dual runner inlet manifold) and JDM Si/SiR but it has lower compression than the JDM Si. The B18C4 has 10:1 CR as opposed to 10:6:1 of the JDM Si/SiR
Old Mar 26, 2006 | 11:02 AM
dohcMONSTER's Avatar
Default Re: b18c and b18c1....searched (JDMilanoRed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMilanoRed &raquo;</TD></TR><TR><TD CLASS="quote">b18c is JDM only.. but it is not just ITR... it's also sir-g... both are stamped 'b18c'</TD></TR></TABLE>
to verify you have to check the casting on the head.
p72=GSR
pr3=rRRrrRRRRRR
Old Mar 27, 2006 | 04:32 PM
Promina's Avatar
Default Re: (mugenracer)
I won't argue if there is or isn't a C2, but that's what was printed in that issue. So if there isn't a C2, then it looks like Import Tuner misprinted the interview with Mr. Tatsuru Ichishima. But thanks for the correction.
mcc361
Sep 4, 2007 05:27 AM
supdawg
Feb 13, 2007 01:48 PM
tHeeeazy E
Mar 28, 2006 10:52 AM
Hilary_duff
Feb 23, 2005 08:43 AM
insomniac791
Dec 7, 2003 11:46 PM
