rear disc swap and broke some bolts
Old Mar 25, 2006 | 04:34 PM
huge230's Avatar
Default rear disc swap and broke some bolts
I have a big problem here. I was doing a rear disc conversion and broke 2 bolts on the trailing arm that thread into the chassis. What in the hell do I do? Im sure an easy out wont work. I can drill but how will that get the rest of the bolt (threads) out of the chassis? ANy help will be appreciated.
Old Mar 25, 2006 | 04:37 PM
BlueIntegraBoy's Avatar
Default Re: rear disc swap and broke some bolts (huge230)
Maybe drill them out and retap the holes.
Old Mar 25, 2006 | 04:38 PM
huge230's Avatar
Default Re: rear disc swap and broke some bolts (BlueIntegraBoy)
im guessing it would be pretty hard to tap into that. Id like to get the broken bolt out somehow
Old Mar 25, 2006 | 04:43 PM
spoonracer84eg's Avatar
Your probably going to have to drill it out.
Old Mar 25, 2006 | 04:44 PM
Vlad79's Avatar
My suggestion is to drill out the center like you are using and Easy Out, but before you use and easy out get it glowing red hot with and Oxy/Acetylene torch. It should come right out
Old Mar 25, 2006 | 04:45 PM
NonovUrbizniz's Avatar
Loved
It's most likely a welded in nut anyhow... IE you CAN'T retap.. safely at least...
If the bolt snapped where it's still flush or above the surface you could notch it and try using a flat head screwdriver or a chisel to turn it out.
Chisels work GREAT but theres a technique to it and sometimes you just don't have the clearance to use it.
Old Mar 25, 2006 | 04:49 PM
huge230's Avatar
Default Re: rear disc swap and broke some bolts (NonovUrbizniz)
it actually broke up in the chassis. Hopefully easy out while red hot works
Old Mar 25, 2006 | 04:51 PM
A.E Motoring's Avatar
samething happend to me, pretty much, drill out the broken bolt, then get a helicoil they sell them at your autoparts store, drill it out then retap the hole and install the helicoil, or just try to get that broken bolt out
Old Mar 25, 2006 | 06:41 PM
Default Re: rear disc swap and broke some bolts (SPNFEDEH)
Dont use an easy out. You will break it. Use a drill to drill it out but get a bit smaller than the bolt and drill right in the middle of it. The remainder of the bolt might come loose.
Old Mar 25, 2006 | 07:06 PM
dem0nk1d's Avatar
Screw extractor. You'll need to drill a hole into the bolt, and thw screw extractor has reverse threads.
Old Mar 25, 2006 | 07:39 PM
blacklx97's Avatar
you might also try a left- handed drill bit and run your drill in reverse. i have had luck with this in the past. the heat created by drilling helps, and sometimes the bit will bite and since it is turning left handed, it will loosen or even spin the bolt out. these types of drill bits are sometimes available at good hardware stores, otherwise at a machine tool supplier that carries all kinds of drills, dies, taps, etc. hope this helps. also it doesn't sound like the bolt is sticking out at all, but if it is, you could weld a nut onto it and turn it out.
Old Mar 25, 2006 | 09:44 PM
vtecpoweredsol's Avatar
this happened to me. u cant drill em out, no bit we had could do it, those bolts are hardcore.. i just ended up buying new trailing arms, $91 shipped
Old Mar 25, 2006 | 09:58 PM
Karizmah's Avatar
Default Re: (vtecpoweredsol)
You can drill it out with a carbide drill. But you have to start with a flat surface and spot drill it first directly in the center. Also the other ideas might work too.
Old Mar 26, 2006 | 06:10 AM
huge230's Avatar
Default Re: (Karizmah)
there is no peice of the bolt sticking out. If I try and drill and use an easy out, how much of the bolt should I leave for the EX out the grab? I mean the more I drill out the easier it should eb to get out.
Old Mar 26, 2006 | 03:53 PM
Karizmah's Avatar
Default Re: (huge230)
I would just make damn sure to be as close as possible to the center. If the surface is not flat just use a die grinder if you can get it in there to grind a flat.
USE A SPOT DRILL FIRST, Or else your drill will wander. I would drill out at least half way doun and then try an extractor.
Old Mar 28, 2006 | 10:16 AM
huge230's Avatar
what extractor do I want to use?
one like this
http://cgi.ebay.ca/NEW-DRILL-O...wItem
I tried the ones like this but it doesnt do anything. It doesnt grab at all
http://cgi.ebay.ca/SCREW-EXTRA...wItem
Old Mar 28, 2006 | 02:32 PM
Karizmah's Avatar
I would give it a try. If as a last resort you may have to take it to a mechanic..
Charlie Moua
15
Sep 5, 2014 01:51 PM
madgeo
Jul 12, 2009 07:56 PM
dohctor_B
30
May 13, 2007 12:40 AM
EGhatch33
Suspension & Brakes
24
Jan 2, 2006 10:01 AM
Integra_Nguyen
Aug 10, 2002 06:58 PM
