Possible to TIG weld this groove shut on block?
Old Mar 25, 2006 | 04:18 PM
dunkd's Avatar
Default Possible to TIG weld this groove shut on block?
Here's the story of what's going on with my block... https://honda-tech.com/zerothread?id=1570279
I tried JB welding this groove closed to prevent the coolant from leaking but it did not work... I am thinking my next route would be to find someone to fill the groove in with weld and close up the groove completely. Then sand down the area to make it all flat. Any idea's?
Circled in red is the groove I am talking about.
Here it was it looked like with the JB Weld in it right before I put it back together. I let it cure overnight and it was solid in the morning. I thought it was going to work out good but I guess not .
Old Mar 25, 2006 | 04:26 PM
B18C1CYA's Avatar
Default Re: Possible to TIG weld this groove shut on block? (dunkd)
the only bitch is going to be getting all the jb weld out , but yeah I would just weld it shut and grind it down
Old Mar 26, 2006 | 06:18 AM
HamiltonRex's Avatar
Default Re: Possible to TIG weld this groove shut on block? (B18C1CYA)
Dont waste anymore time, just weld it up.
Old Mar 26, 2006 | 09:36 PM
JDMCRX's Avatar
Default Re: Possible to TIG weld this groove shut on block? (HamiltonRex)
Take a dremel grind the **** out of it make it wide and slam the tig in there and fill it in them file it smooth
Old Mar 26, 2006 | 11:51 PM
wantboost's Avatar
Who is Mr Robot?
you cant weld that shut. the timing belt tensioner has a nub that follows that groove
Old Mar 27, 2006 | 12:07 PM
Default Re: Possible to TIG weld this groove shut on block? (wantboost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote">you cant weld that shut. the timing belt tensioner has a nub that follows that groove</TD></TR></TABLE>
very good point
Old Mar 27, 2006 | 12:27 PM
ManBearPig4silly's Avatar
How deep does the tab need to go? If ther eis enough room you could tig it and leave enough clearance for the tab.
btw how did he put it together with the jb weld sanded flush?
Old Mar 27, 2006 | 07:06 PM
dunkd's Avatar
care to post a pic of that? mine does not have anything that follows the groove. the inner ring on the tbelt tensioner does not even line up with the groove.
98EGY8
Engine Machining & Assembly
Dec 16, 2016 07:50 PM
The Arp
22
Nov 18, 2010 07:34 PM
punkracer
Sep 21, 2010 08:26 AM
Turbo-Honda
Welding / Fabrication
Apr 7, 2006 08:29 PM
jDMJeRk
Jan 22, 2004 11:24 PM
