Need steps to bleed brakes
Old Mar 25, 2006 | 12:33 PM
puffthomas's Avatar
Default Need steps to bleed brakes
I searched and couldn't find the steps. I need the pattern to bleed the brakes.
thanks
Old Mar 25, 2006 | 12:39 PM
fast+forward's Avatar
Default Re: Need steps to bleed brakes (puffthomas)
farthest to closest..passenger rear..driverside rear, passenger front, driverside front
Old Mar 25, 2006 | 02:58 PM
typeoneeg6's Avatar
Default Re: Need steps to bleed brakes (---+)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ---+ &raquo;</TD></TR><TR><TD CLASS="quote">farthest to closest..passenger rear..driverside rear, passenger front, driverside front</TD></TR></TABLE>
+1. thats correct.
Old Mar 25, 2006 | 02:59 PM
wrinkles's Avatar
exactly
Old Mar 25, 2006 | 05:04 PM
BlueIntegraBoy's Avatar
Default Re: (wrinkles)
According to the Helms manual, it's...
Old Mar 25, 2006 | 05:11 PM
jerbear!'s Avatar
so which one is it? i've seen both and im still confused.
Old Mar 25, 2006 | 05:18 PM
SVOboy's Avatar
Default Re: (jerbear!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jerbear! &raquo;</TD></TR><TR><TD CLASS="quote">so which one is it? i've seen both and im still confused.</TD></TR></TABLE>
Both of the suggestions are the same, , look at the picture.
Old Mar 25, 2006 | 06:17 PM
dfoxengr's Avatar
Default Re: (SVOboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SVOboy &raquo;</TD></TR><TR><TD CLASS="quote">Both of the suggestions are the same, , look at the picture. </TD></TR></TABLE>
theyre not both the same...
Old Mar 25, 2006 | 06:21 PM
SVOboy's Avatar
Good point, I can't read numbers, in which case, I'd say go with what the helms manual says to do.
Old Mar 25, 2006 | 06:25 PM
dfoxengr's Avatar
ive also heard the diagonal way is the way to do it.
Old Mar 25, 2006 | 06:27 PM
greddydc5's Avatar
how you doing first
- you need two people
- you only need to bleed what you changed meaning if you changed the right rotor and pads u only bleed that one, if you changed both bleed both.
- you will need a size 10 open end rachet
- you will also need dot 3 drake fluid to refill
- now you can start
- have one person sit in the driver side
- have them pump the brakes 3 times and then hold the brake down
- once he holds it down the next person opens the nipple
- once you open it and see fluid come out close it right away
- continue this step four times then you will be ready to go
- after that then u refill it then you'll be ready to hit the streets
P.S. i hope these steps help you alot have fun and HAPPY TUNING
A MEMBER FROM TN... JUST HELPED YOU
Old Mar 25, 2006 | 06:53 PM
1995Ex_Sedan's Avatar
You shouldn't have to bleed it if you changed the rotor and pads.
Old Mar 26, 2006 | 03:12 AM
Project_99Hatchback's Avatar
you only need to bleed the brakes if you cracked the system or boiled the brake fluid from hard braking, however to keep things stiff and fresh meaning no old dirty fluid best practise is to bleed the breaks when you change the pads not mandatory tho
Old Mar 31, 2006 | 07:49 PM
Cuppycake's Avatar
Does this process change if you have rear drums?
Big red89
May 9, 2008 06:18 PM
old-sk0ol
Jun 3, 2007 12:01 PM
SLAMMED_EF8
Apr 12, 2006 09:09 AM
TypRice
Dec 13, 2005 06:32 AM
SuicideSlide
Jul 13, 2004 10:14 AM
