how to tell if obd1
Old Mar 25, 2006 | 11:49 AM
ahthisguyhere's Avatar
Default how to tell if obd1
Ok i didnt know who to search for something like this. I just bought another ls and in the car it says 10 of 91 on door tag. I looked under the hood there is no resister box and the dizzy plug look different its grey square not white round. Is the motor obd1? Thanks if anybody can help.
Old Mar 25, 2006 | 12:11 PM
Default Re: how to tell if obd1 (ahthisguyhere)
bump
Old Mar 25, 2006 | 12:34 PM
Redline130's Avatar
Sounds like it is OBD1. If you can post a pic, that would definitely help.
Old Mar 25, 2006 | 01:52 PM
Immanuel's Avatar
Default Re: how to tell if obd1 (Redline130)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ahthisguyhere &raquo;</TD></TR><TR><TD CLASS="quote"> I looked under the hood there is no resister box and the dizzy plug look different its grey square not white round. .</TD></TR></TABLE>
Yeah its OBD 1
If the plugs are milky white = OBD 0. If the plugs are grey = OBD 1
jlicrx's Avatar
10/91 would indicate that it is 92 model which is OBD1 and would have square gray distributor connector - would also have MAP sensor on the throttle body and cooling fan switch on the thermostat housing
Old Mar 25, 2006 | 03:00 PM
Default Re: how to tell if obd1 (1.6 DOHC ED9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1.6 DOHC ED9 &raquo;</TD></TR><TR><TD CLASS="quote">
Yeah its OBD 1
Old Mar 25, 2006 | 04:23 PM
does this make it easier to tune the ecu if i go obd1 or should i stay obd0 sorry for such noob questions just dont know much bout the ecus and all
Old Mar 25, 2006 | 04:41 PM
go obd-1....so much more opportunities with everything. less hassle
don't forget the conversion harness
Old Mar 26, 2006 | 12:50 AM
nikitad's Avatar
Default Re: (!vega_boxes!)
no harness needed. you ARE obd1.
Old Mar 26, 2006 | 04:07 AM
how am i obd1 i have an 88 civic four door well kool
Old Mar 26, 2006 | 01:07 PM
nikitad's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ahthisguyhere &raquo;</TD></TR><TR><TD CLASS="quote"> I just bought another ls and in the car it says 10 of 91 on door tag. </TD></TR></TABLE>
This is what I read.
LS + grey plugs + end of 91 = OBD1
If you meant that the donor car had that, and you do drive an OBD0 car then, well.... OBD1 has good tuning choices, but you can get by with OBD0 as well.
Of course you'd need a 90-91 ls distro in that case, and perhaps resistor box with injectors.
Old Mar 26, 2006 | 01:56 PM
Immanuel's Avatar
Default Re: how to tell if obd1 (nikitad)
well which is it? You have an 88 civic or and LS? Once again look at the FAWKIN plugs, Milky white = OBD 0 and Grey = OBD 1
any HOnda from 88- 91 is OBD 0
92-95 = OBD 1
96 + in OBD 2
Old Mar 26, 2006 | 03:55 PM
oh man im sorry i have a 88 civic now withobd0 ls in it and im bought another ls to rebuild for turbo (i cant have down time on my car) and the newer motor is what im asking about
Old Mar 26, 2006 | 06:23 PM
K DOHC_19's Avatar
Default Re: (ahthisguyhere)
OBD1
Old Mar 26, 2006 | 09:04 PM
boostedblkef's Avatar
Default Re: (K DOHC_19)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by K DOHC_19 &raquo;</TD></TR><TR><TD CLASS="quote">OBD1 </TD></TR></TABLE>
itr909
Jun 3, 2009 08:38 AM
ivan93egreppin210
May 15, 2009 09:26 PM
6doorsentra
Feb 11, 2007 06:57 PM
88'hcrx
Jan 11, 2007 04:00 PM
whitehatch11
11
Jun 28, 2003 07:50 PM
