Noisy Valves
So after my rebuild, which had nothing to do with the top end, and after setting the valve lash, .006 & .007, I started my caR and the valves were making a ton of noise. My caR has always been noisy but not like this. Even after letting it warm up they still made lots of noise. I am ging to go back and readjust everything, but I don't think that it will make much difference.
So does anyone have any suggestions as to what else I could check? Thanks in advance
ain't .004 and .006 result in too tight valves?
it could be you're LMA making that noise.
after putting the bc3+ in my head and adjusted them to the buddy club spec does it make ticking noise. but since it is after manufactures spec would i guess it would be okay.
stiffer valvesprings? maybe the valves are opening/closing with more force and making more noise. my crower springs with RC injectors are loud as **** even when perfectly adjusted.
It might just be from collapseing the lifters when you checked the lash. Did you check the lash on the engine cold? Also, I have some slack between the distributor and the cam shaft on my R and it kinda makes the same noise.
Well I have had this head set-up for a while now, JUN III's, with all the valvetrain goodies, RC 440's, I did the valve lash while the engine was cold, the pump was primed. It does not sound like an injector noise, it sounds more slappy or ticky.
I have not had a chance to go back and play with things since I fired it up two weeks ago. Do you think that it is safe to try going with a tighter clearence?
anytime Ive tried to run on the tight side of spec, it always seems to make the car feel bogged down. I usually run middle to loose (within spec) as far as valve clearance goes and just check them often.
1990hondaHF
Oct 1, 2002 10:23 AM
