Car runs really rich
ALright I have a 91 HF w/ D16Z6 swapped in. It is still running a PM6 ECU and the original injectors. P28 swap and SI injectors are going in when I get a chance.
Problem is that the car runs and smells really rich in the interior when idling. I know its running rich because the AF gauge is stuck on rich.
What could be the cause of this? How do I know what pressure the FPR is set at? Can timing cause a rich state? Could the smell be a bad fuel filter?
Thanks guys.
Thanks guys.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pinecone »</TD></TR><TR><TD CLASS="quote"> How do I know what pressure the FPR is set at? Can timing cause a rich state? Thanks guys.</TD></TR></TABLE> 1st off get the right ecu (p28) and injectors. do you have any ecu codes right now??.....if you wanna know your fuel pressure hook up a pressure gauge (i did mine on the fuel filter).......and yes your timing can effect your a/f mixture
I know, I need to get a new VTEC solenoid and a O2 sensor(which aren't cheap) so I can hook up the conversion harness.
I will look into the timing and the fuel pressure. Hopefully they have those that I can rent at Autozone. Also how do I adjust the fuel pressure, can I do that on the gauge or do I need something else?
No codes at all.
No codes at all.
Well I would check my timing, but oh wait, there is no timing cover, great. Even if I had a timing cover, it is gonna be a pain in my butt to remove the one bolt holding my dizzy on. Isn't there supposed to be some kind of mark on the gear, what if it isn't a stock gear, would it still be there?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">I know its running rich because the AF gauge is stuck on rich.
Problem is that the car runs and smells really rich in the interior when idling</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pinecone »</TD></TR><TR><TD CLASS="quote">I know, I need to get a new VTEC solenoid and a O2 sensor
No codes at all.</TD></TR></TABLE> i have an extra v-tec solenoid that ill sale you if you want? and to adjust your fuel pressure you need to use an adjustable fuel pressure regulator (you can usually find a b&m regulator used for around $20 in the classifieds)<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pinecone »</TD></TR><TR><TD CLASS="quote"> Isn't there supposed to be some kind of mark on the gear, what if it isn't a stock gear, would it still be there? </TD></TR></TABLE>which gear? do you mean your cam gear? if so yes there should be some sort of mark (if it's stock there will be a stamp/arrow saying/pointing up) if it's a aftermarket gear i couldnt say for sure
</TD></TR></TABLE> also a narrow band a/f gauge (im assuming you have a narrowband) is ok to get an idea of what you a/f is but it isnt 100% accurate (im being nice) so dont count on the gauge too much
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pinecone »</TD></TR><TR><TD CLASS="quote">I know its running rich because the AF gauge is stuck on rich.
Cool, I'll send you a pm about the solenoid.
I am not sure if its a stock cam gear or not. I know the gear on top is aftermarket, not sure about the other one's. The guy I bought the car from said it had underdrive pulleys, I believe. I'll have to ask him again.
I know the gauge is a general type thing, but when it sits pegged on rich when its idling, I tend to think its running a lil rich. Also the really really strong fuel smell in the interior is a strong indicator of a rich fuel environment.
i put a d16z in my 88 crx si when you do the conversion be sure to hook the knock sensor up on the back of the engine or you will get no spark and there is no place to hook the idle actuator control valve up on mine there is just no clip or anything but i got mine to run on the new com but not over 3500 rpm
I'll have to look, but wouldn't it be throwing a code or running even crappier if the IACV was not hooked up right. I know it had fallen off during a drive around the block and the car just wanted to die.
underpressure02
Oct 21, 2005 05:44 AM
a1320honda
Apr 12, 2005 07:24 AM
