ITR owners with water temp gauge / OBDII readers, pls come in
done a search but nothing came out. if you are an owner of one of those gadgets above, pls add into this list. Hope it may come useful to those of us w/o monitoring devices.
Example 1
Brand: Stock monitored by OBD2 reader
Temp when needle at
Cold: 70F
2nd mark: 80F
3rd mark: 100F
4th mark: 120F
center mark: 140F
6th mark: 155F
Example 2
Brand: Defi
Temp when needle at
Cold: 35C
2nd mark: 45C
3rd mark: 70C
4th mark: 90C
center mark: 100C
6th mark: 105C
Hope you guys can juz add on below:
Nick:
Brand:
Temp when needle at
Cold:
2nd mark:
3rd mark:
4th mark:
center mark:
6th mark:
Nick:
Brand:
Temp when needle at
Cold:
2nd mark:
3rd mark:
4th mark:
center mark:
6th mark:
Nick:
Brand:
Temp when needle at
Cold:
2nd mark:
3rd mark:
4th mark:
center mark:
6th mark:
Example 1
Temp when needle at
Cold: 70F
2nd mark: 80F
3rd mark: 100F
4th mark: 120F
center mark: 140F
6th mark: 155F
Example 2
Brand: Defi
Temp when needle at
Cold: 35C
2nd mark: 45C
3rd mark: 70C
4th mark: 90C
center mark: 100C
6th mark: 105C
Nick:
Brand:
Temp when needle at
Cold:
2nd mark:
3rd mark:
4th mark:
center mark:
6th mark:
Nick:
Brand:
Temp when needle at
Cold:
2nd mark:
3rd mark:
4th mark:
center mark:
6th mark:
Nick:
Brand:
Temp when needle at
Cold:
2nd mark:
3rd mark:
4th mark:
center mark:
6th mark:
Example 2
Brand: None
Temp when needle at
Cold: Cold
2nd mark: 2nd mark
3rd mark: 3rd Mark
4th mark: 4th Mark
Center mark: Never gets that far
6th Mark: Never got that far...and I hope it never does
Brand: None
Temp when needle at
Cold: Cold
2nd mark: 2nd mark
3rd mark: 3rd Mark
4th mark: 4th Mark
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mugenracer »</TD></TR><TR><TD CLASS="quote">Example 2
Brand: None
Temp when needle at
Cold: Cold
2nd mark: 2nd mark
3rd mark: 3rd Mark
4th mark: 4th Mark
6th Mark: Never got that far...and I hope it never does</TD></TR></TABLE>
actually, you are right
mine has been hovering around the 4th mark all the time; slightly lower when cruising on a cold night, slightly higher when things get hot.
Brand: None
Temp when needle at
Cold: Cold
2nd mark: 2nd mark
3rd mark: 3rd Mark
4th mark: 4th Mark
Nick: F... Chris F.
Brand: Defi
Location: In my car measuring oil at the sandwich plate, but could measure water
Temp when needle at
Cold: 85 F
2nd mark: 90
3rd mark: 95
4th mark: 100
5th mark: 105
.. there are 44 marks...
44th mark: 300 F
Gauge keeps turning another 3-4 marks past 300.
Do you not trust aftermarket gauges? Or are you trying to figure out what the OEM marks match up to?
the 4th mark has to be from ~170 thru ~200, it just stays there even if your car gets "pretty" hot. I've had it a couple marks past that, but it was stupid hot.
Brand: Defi
Temp when needle at
Cold: 85 F
2nd mark: 90
3rd mark: 95
4th mark: 100
5th mark: 105
44th mark: 300 F
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by powersteer »</TD></TR><TR><TD CLASS="quote">
mine has been hovering around the 4th mark all the time; slightly lower when cruising on a cold night, slightly higher when things get hot.</TD></TR></TABLE>
Mine never ever ever budges from the mark just below the centre mark, no matter how cold or hot it is outside...thats why i have a GReddy gauge going in shortly, i've had the gauge for ages but was waiting to get the coolant pipe adaptor sleeve to mount the sensor in.
mine has been hovering around the 4th mark all the time; slightly lower when cruising on a cold night, slightly higher when things get hot.</TD></TR></TABLE>Mine never ever ever budges from the mark just below the centre mark, no matter how cold or hot it is outside...thats why i have a GReddy gauge going in shortly, i've had the gauge for ages but was waiting to get the coolant pipe adaptor sleeve to mount the sensor in.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris F »</TD></TR><TR><TD CLASS="quote">Nick: F... Chris F.
Brand: Defi
Temp when needle at
Cold: 85 F
2nd mark: 90
3rd mark: 95
4th mark: 100
5th mark: 105
44th mark: 300 F
the 4th mark has to be from ~170 thru ~200, it just stays there even if your car gets "pretty" hot. I've had it a couple marks past that, but it was stupid hot.</TD></TR></TABLE>
oh sorry if i hadnt put it across clearly, what i'm actually trying to gather is to know wat temp does ur defi (or others) reads while the stock gauge in ur meter cluster points to 3rd, 4th marking ... etc
it will be really kind of you if you can observe those things with your Defi and add to the list
Brand: Defi
Temp when needle at
Cold: 85 F
2nd mark: 90
3rd mark: 95
4th mark: 100
5th mark: 105
44th mark: 300 F
My defi is measuring oil temp, though it could measure water.
So I'm not much use.
Water temp seems to be mostly useless.
The OEM gauge is pretty worthless too.
-Chris
</TD></TR></TABLE>My defi is measuring oil temp, though it could measure water.
So I'm not much use.Water temp seems to be mostly useless.
The OEM gauge is pretty worthless too.-Chris
