ek9ctr cams
Old Mar 24, 2006 | 05:17 PM
mtownsi's Avatar
Default ek9ctr cams
hey wats good does anyone have any info on the ek9(pct) ctr intake cam that is being sold on hmotorsonline for $240. i emailed them but they didnt gwt bak to me and the website dont have any info bout them ok thanks
Old Mar 25, 2006 | 11:54 AM
mtownsi's Avatar
Default Re: ek9ctr cams (mtownsi)
bimp bump
Old Mar 25, 2006 | 01:26 PM
NAem1's Avatar
what do you want to know about it?
Old Mar 25, 2006 | 05:47 PM
mtownsi's Avatar
the lift and duration if there a direct swap into a 99si and wat does pct mean
Old Mar 25, 2006 | 07:24 PM
-JSpecEk*9-'s Avatar
pct is the ctr code. like b16 is pr3
Old Mar 26, 2006 | 10:19 AM
NAem1's Avatar
Default Re: ek9ctr cams (JDMEK-9)
yes you can run them on the stock B16 valve train IF you plan on leaving the stock rev limit at 8200.
-On the CTR cams the intake is 11.5mm and the exhaust is 10.5mm
I dont know what your goals or money options are set at but for about 100 bucks more you can pick up a set of Skunk2 stage 1 cams which would put out a little more power then the CTR's
Old Mar 26, 2006 | 05:20 PM
mtownsi's Avatar
Default Re: ek9ctr cams (NAem1)
ok thank you also am i gonna have to retime moy motor for the cam or can i leave it
Old Mar 26, 2006 | 05:32 PM
NAem1's Avatar
well if you go with the stage 1 cams I would get a set of cam gears and some type of tuning program... hondata, crome, etc... and bring the car to the dyno and get them tuned. I've seen B16's with the stage 1 cams with 18 degrees of timing, but each motor is different
Old Mar 26, 2006 | 05:54 PM
mtownsi's Avatar
well im gonna buy the ek9 ctr cam and the ctr pistons from hmotors
BrandonB16
10
Feb 14, 2009 09:06 AM
richieTN
Mar 26, 2007 09:42 AM
jaydeeumms
16
Aug 30, 2005 07:41 AM
limpy
Apr 8, 2004 01:36 PM
-Whitey-
11
Oct 4, 2002 07:35 AM
