cams
cams
ok so i have a civic si (b16) somewhat stock engine just the little things like intake manifold, intake, etc. but i wanted to know what cams people thought would be best for me to put throw into it and what all i need to get for them anything helps
Re: cams
CTR Intake cam...will give you the noticeable "PEP" i think your looking for. Not too crazy expensive, also a STOCK part from Honda, so you know it will be reliable. Also, you dont want to go TOO crazy with cams unless you are going to get into port matching, cam gears, etc...The exhaust cam has just a little bit of difference i believe from your stock B16.
Re: cams
With just minor mods like you have, I would go with the skunk2 stage 1 cams. You will need a tune but with a tune you will see some solid gains...
Re: cams
both of those are some good choices and both of those you will need to tune to maximize the power out of them but i would also run some retainers and springs with the skunk2 just for safety sake but you will be good with the ctr imo
Re: cams
With stage 1 skunk2's you shouldn't have to start swaping out valve train parts, it's after that they recommend changing your springs and retainers right?
Both of these are great recomendations, just look into good companies and see what they offer and what you think will work for you. Just remember, for some reason the specs that are advertised aren't the actual specs of the cam. Thiers always an actual spec and an advertised spec. Why the cam companies don't just give the actual spec as the spec instead of giving you some other spec, i don't know.
Crower is one of my favorites. But skunk2 and CTR cams are great choices.
Re: cams
anyways op this partains to your question anywas so i will ask cuz i wanna know
IS IT REALL WORTH GETTING A B17 CRANK IN A B16 block
and where do they sell the b17 cranks
also i will be having to use the b17 rods but which pistons do i have to use
Re: cams
just a quicky ... i like itr cams cheap and u can use stock valve train if ur not reving past 8k ....
whats with the one intake cam being used why not use both itr or ctr cams
Using Skunk 2 stg. 1 cams or CTR intake cam on a bone stock B18C1.........wat can I expect from it??
1JDMDOMINICAN
25
09-06-2006 03:19 PM
