is it ok to block off the egr
Old Mar 24, 2006 | 03:32 PM
A-busive's Avatar
Default is it ok to block off the egr
http://cgi.ebay.com/ebaymotors...wItem
You are bidding on an insulating Intake Manifold EXTREME PPP Gasket for the 92-95 Honda Civic Si with d16z6 vtec motor. This item is brand new. This version provides maximum horsepower gains by<U> blocking off the Exhaust gas recirculation </U>(EGR) which dumps hot exhaust gases into your intake stream, as well as blocking coolant flow to the intake manifold. This item is brand new. We also have another version which does not block off the EGR/Coolant flow, please view our other auctions.
Is it ok to get this for my d16z6 hooking up the skunk2 IM
Old Mar 24, 2006 | 03:41 PM
A-busive's Avatar
Default Re: is it ok to block off the egr (A-busive)
and how come all the gaskets for the manifold have the big hole on the bottom left up and not on the bottom
example:the big hole on the bottom???all other gaskets big hole is on the top, is it just a sample picture on ebay pics?
Old Mar 24, 2006 | 06:06 PM
A-busive's Avatar
bump
Old Mar 24, 2006 | 06:29 PM
schardbody's Avatar
well, seeing as how a stock z6 doesnt have an EGR that isnt going to matter.
Old Mar 24, 2006 | 09:17 PM
weezo182's Avatar
BUMP
Old Mar 25, 2006 | 07:41 PM
A-busive's Avatar
Default Re: (schardbody)
O well thanx, well wtf is egr
Old Mar 25, 2006 | 07:54 PM
rukawa1one's Avatar
As long as I dont have to take out any more Metal Gears
I believe that JDM engines dont come with EGR valves
Old Mar 25, 2006 | 07:59 PM
A-busive's Avatar
Default Re: is it ok to block off the egr (rukawa1one)
i have a usdm d16z6 so its ok to get it??But is the egr really sumin to worry about
Old Mar 25, 2006 | 08:44 PM
rukawa1one's Avatar
EGR has somthing to do with smog, i guess u can just re-install it when u do a somg check
Old Mar 25, 2006 | 08:48 PM
A-busive's Avatar
awww ok thanx alot guy
Old Mar 25, 2006 | 09:22 PM
posite's Avatar
egr = exhaust gas recirculation. This is only at idle and maybe low rpms and does not noticably affect performance or gas mileage in any way and may actually make your car idle rough if blocked.
Old Mar 26, 2006 | 06:39 AM
schardbody's Avatar
WTF, the egr is operative at idle and low load situations (cruising). basically just letting exhaust back into the intake to burn it again. it keeps the CC temps down a little as well which is good for long highway runs. it wont make the engine run rough if blocked. mine is blocked (d15z1) if anything it wiil idle better without the exhaust coming back in. BUT the whole reason i posted was to say you dont even have an egr on your car.
coco502
20
Jan 4, 2010 08:05 PM
apekd
12
Apr 19, 2009 05:25 AM
NZDelsoldude
Feb 16, 2006 01:18 PM
Sinner
Jun 4, 2003 05:59 AM
