ECU CUT OFF SWITCH
i have heard of people making a special jumper harness... like you splice in some connectors between the wires and pull that harness so there is a gap between the ecu connectors and wire when its moved...
D1-VBU Back Up Power Wht/Yel, Battery positive From battery through Fuse Box, Battery Voltage at ALL times
D1 is the pin/wire you would want to run a switch to. That will prevent the ECU from turning on.
Splat
Jan 7, 2002 07:00 AM
