CX Vtec-E Dizzy on a d16z6
Old Mar 24, 2006 | 09:09 AM
SupraRXZ's Avatar
Default CX Vtec-E Dizzy on a d16z6
would it prevent my car from starting if i used a CX dizzy on a d16z6
cause it has VtecE not sure if its the same dizzy tho
Im doing a DPFI obd0 to MPFI obd1
i get crank and fuel but no spark at all
Old Mar 24, 2006 | 09:15 AM
Gojira D.O.T's Avatar
d16z6 does not have vtec-e and yes you need the dis for the z6 head
Old Mar 24, 2006 | 10:56 AM
hatchi's Avatar
Default Re: CX Vtec-E Dizzy on a d16z6 (SupraRXZ)
i believe it wont bolt up.
Old Mar 25, 2006 | 02:04 PM
SupraRXZ's Avatar
oh ok so it wont spark at all? it bolts on perfectly
Old Mar 25, 2006 | 02:15 PM
SVOboy's Avatar
I just did my dpfi obd0 to mpfi obd1, used a d16y8 dizzy and everything ran well. Did you mean vx vtec-e dizzy? It will bolt to the z6 just fine. Anyway, good luck, there should be no problem is the dizzy bolts up.
Old Mar 25, 2006 | 02:20 PM
SupraRXZ's Avatar
I get fuel and crank but no spark, it bolts right on it perfectly
Old Mar 25, 2006 | 02:34 PM
SVOboy's Avatar
Hmm, I've got no help for you then, are you sure the dizzy is good?
Old Mar 25, 2006 | 03:09 PM
SupraRXZ's Avatar
ya it came off of my bros car and his is running were just using it rite now to see if it starts, cause my other dizzy has a MSD set up on it so we wanna try the stock one first
Old Mar 25, 2006 | 03:13 PM
SVOboy's Avatar
Good luck, you'll love the swap when it's done,
Old Mar 25, 2006 | 05:14 PM
SupraRXZ's Avatar
can anyone else give there opinion?
Old Mar 26, 2006 | 11:49 AM
SupraRXZ's Avatar
bump
Old Mar 26, 2006 | 12:34 PM
drewbie*'s Avatar
Default Re: (SupraRXZ)
cx = d15b7 = non vtec
Old Mar 26, 2006 | 12:56 PM
SupraRXZ's Avatar
Default Re: (Drew95eg)
well its a vtecE engine iunno CX or VX but its vtecE
Old Mar 27, 2006 | 03:38 PM
drewbie*'s Avatar
if the engine stamp is d15z1 then its vtec e
Old Mar 27, 2006 | 04:10 PM
BauleyCivic's Avatar
Risky Business
If you got it to bolt up it should work fine...are the plug wires in the right order?
Old Mar 27, 2006 | 04:55 PM
fmrprojects's Avatar
Default Re: (BauleyCivic)
put it in and start it up
civicDX95
Jan 3, 2014 12:15 PM
koalayummies
Nov 17, 2011 03:04 PM
Looneytunerz
Dec 24, 2010 09:21 AM
theemaddhatterr
Jun 28, 2005 01:50 PM
