Signs of a Bad 02 Sensor? What are they?
Old Mar 24, 2006 | 07:37 AM
mikeunreal2's Avatar
Default Signs of a Bad 02 Sensor? What are they?
My car is idling and running like ****. I have no cels. Its on my 92 hatch with b16a. Could a bad 02 sensor causing erratic rough idling and rich running? Please help.,
Mike
Old Mar 24, 2006 | 07:41 AM
philosofy1's Avatar
Default Re: Signs of a Bad 02 Sensor? What are they? (mikeunreal2)
rough idle, hesitation when accelerating, burning excessive fuel, and of course a cel.(sometimes a cel)
Old Mar 24, 2006 | 07:50 AM
Default Re: Signs of a Bad 02 Sensor? What are they? (philosofy1)
someone just told me that you cant run aftermarket headers on hondas bc it flows too much and the 02 sensor can't work with them. is this true?>
Old Mar 24, 2006 | 08:02 AM
snatch's Avatar
You can run aftermarket headers on a Honda and the O2 sensors will still work.
Old Mar 24, 2006 | 08:03 AM
philosofy1's Avatar
Default Re: Signs of a Bad 02 Sensor? What are they? (******)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ****** &raquo;</TD></TR><TR><TD CLASS="quote">You can run aftermarket headers on a Honda and the O2 sensors will still work.</TD></TR></TABLE>
Old Mar 24, 2006 | 08:31 AM
anyone else agree?
Old Mar 24, 2006 | 10:58 AM
hatchi's Avatar
Old Mar 24, 2006 | 11:01 AM
bag's Avatar
bag
usualy u can tell becuz it will run perfect wen 1st startup,,then abowt 10min later it running shity an rich,,an pops a cel usuly..
do u hav any afermarket mods that may bee causing this condishin.
Old Mar 24, 2006 | 11:51 AM
hondadriver's Avatar
Default Re: Signs of a Bad 02 Sensor? What are they? (BRIJPURT13B)
I had a bad O2 and i didn't get a code for it either! I did a mini-me on my y7 in my 98 lx, and i was running lean as hell, my a/f gauge stayed on the lean side no matter what! And I did a search, talked to some good mechanics, and they told me to change the ecu cuz the fuel map is different for the vtec head!!! well I did and it didn't solve the problem. I tested my O2 like 100 times and it checked out good. So a month later I said expletive it and ordered a used O2 sensor from HAP and BAM fixed the prob!!! It was weird, becasue these OBD2 ecus are crazy with throwing codes, but it didn't throw one for my o2 in this situation!!!
livedew12
Jan 10, 2012 08:58 PM
itzyaboyzeem03
Oct 16, 2008 11:15 PM
Midori Green
28
Oct 18, 2007 09:43 PM
hometheaterman
Jul 26, 2005 07:56 AM
eswaroop
Apr 14, 2004 11:17 AM
