sleeving?
a stock sleeved LS block cant be bored out to 84mm. the max you can do and thats already pushing it is 82mm. The safest bore size that you can do Max on stock sleeves is 81.5mm
If you are doing 84mm, you HAVE to sleeve it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by exospeedAMcrx »</TD></TR><TR><TD CLASS="quote">a stock sleeved LS block cant be bored out to 84mm. the max you can do and thats already pushing it is 82mm. The safest bore size that you can do Max on stock sleeves is 81.5mm
If you are doing 84mm, you HAVE to sleeve it.</TD></TR></TABLE>
What he said and also what is your intended boost levels?
nickgmiller04
12
Mar 26, 2004 04:07 PM
