removing super glue on car?
Old Mar 23, 2006 | 09:53 PM
H.'s Avatar
H.
Default removing super glue on car?
I decided to take out the "DOHC VTEC" sticker on the back of the car, problem is the Original owner glued it with Super glue. Anyone know a way to get rid of it without damaging the paint job? It looks really nasty too
Old Mar 23, 2006 | 09:54 PM
god.loves.ugly
Guest
Posts: n/a
Default Re: removing super glue on car? (SoCalGsR1)
have you tried "goo gone" ?
maybe nail polish remover I don't know if that will damage the paint though.. might want to test it somewhere thats not visible.
Old Mar 23, 2006 | 09:55 PM
H.'s Avatar
H.
Default Re: removing super glue on car? (Kind_of_a_big_deal)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kind_of_a_big_deal &raquo;</TD></TR><TR><TD CLASS="quote">have you tried "goo gone" ? </TD></TR></TABLE>
never heard of that, but I have tried those decal sprays/bumper removers and didnt work...
Old Mar 23, 2006 | 09:56 PM
RaceMyGhost's Avatar
i have goo gone at home, havent tried it on my car but use it for stains on clothes and stuff and it works wonders...... got it from "walgreens" like 3 bucks or so
Old Mar 23, 2006 | 09:58 PM
god.loves.ugly
Guest
Posts: n/a
Default Re: removing super glue on car? (RaceMyGhost)
I have used it on my car it won't damage the paint but I dont know if its powerful enough to remove super glue that **** really is super. ha ha
Old Mar 23, 2006 | 10:02 PM
H.'s Avatar
H.
where else can i buy this stuff at ?
Old Mar 23, 2006 | 10:07 PM
whats wrong with walgreens?
Old Mar 23, 2006 | 10:15 PM
cm zak's Avatar
brake cleaner?
.water's Avatar
there is no way you can remove them. super glue already ate your paint. so get it done by pro body shop. that sux
Old Mar 23, 2006 | 10:23 PM
H.'s Avatar
H.
Default Re: removing super glue on car? (KPN8CLN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KPN8CLN &raquo;</TD></TR><TR><TD CLASS="quote">there is no way you can remove them. super glue already ate your paint. so get it done by pro body shop. that sux </TD></TR></TABLE>
wtf, plz tell me your kidding
Old Mar 23, 2006 | 10:32 PM
.water's Avatar
super glue eats paint like brake fluid..yumm yumm yumm
Old Mar 23, 2006 | 10:41 PM
Solscud007's Avatar
You can try "debonder" it might eat the paint. I dont know as I have onyl used it for models. It eats cyanoacrylate super glues. which most super glues are made of. go to a hoby store (not michael's) but a true RC/ plstic models store. or model train store and ask for debonder.
it is suppsed to also get super glue off you hands.
Old Mar 23, 2006 | 10:57 PM
.one lane's Avatar
.likes trains
ammonia eats away at adhesives. I don't think it'll eat away at the paint.
Old Mar 23, 2006 | 10:58 PM
. M i c h a e l's Avatar
dotmichael to you
Default Re: (Mr. One Lane)
goo gone..then take a blow dryer to it.
Old Mar 23, 2006 | 11:02 PM
H.'s Avatar
H.
Default Re: (. M i c h a e l)
have u done this before? M i c h a e l
Old Mar 23, 2006 | 11:04 PM
dotmichael to you
Default Re: (SoCalGsR1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SoCalGsR1 &raquo;</TD></TR><TR><TD CLASS="quote">have u done this before? M i c h a e l</TD></TR></TABLE>
its the best known way to get glue off of things. you heat it up so it gets back to its liquid state and goo gone it.
i havent done it with super glue though..but i would imagine it would work. worst comes to worst...you only wasted 5-10 minutes.
Old Mar 24, 2006 | 03:39 AM
M Coop's Avatar
If it gives you too much trouble, just use either 1500 or 2000 grit sand paper and wet sand it off. Once you're done you need to use some rubbing compound to take out the scratches and then buff it with some wax and you'll be good as new. If you're not sure about it just do a test spot so you can see if you can get the scratches out. I'd use a buffer, but if you don't have one you should be able to remove 2000 grit scratches by hand but like I said, do a test spot.
Old Mar 24, 2006 | 07:16 AM
jomama's Avatar
goo gone, WD40, or "goof off"... walmart, tartget, home depot. good luck
Old Mar 24, 2006 | 11:16 AM
solareclipseauto's Avatar
Default Re: (jomama)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by M Coop &raquo;</TD></TR><TR><TD CLASS="quote">If it gives you too much trouble, just use either 1500 or 2000 grit sand paper and wet sand it off. Once you're done you need to use some rubbing compound to take out the scratches and then buff it with some wax and you'll be good as new. If you're not sure about it just do a test spot so you can see if you can get the scratches out. I'd use a buffer, but if you don't have one you should be able to remove 2000 grit scratches by hand but like I said, do a test spot. </TD></TR></TABLE>
i had to do it to one of my customers cars before. he glued the emblems to the car and the only way we got the glue off was to wet sand and then buff out the scratches
K i l l a B e e.
Paint and Body
12
Aug 7, 2007 03:47 PM
Hazem
30
Oct 19, 2004 07:58 PM
Ek9_Mugen
May 4, 2004 04:27 PM
jlamaster
16
Mar 29, 2004 08:56 AM
EM1Guru
Sep 29, 2003 12:39 PM
