How can you remove powder coat?
Re: How can you remove powder coat? (hOnDadiCt)
aircraft remover, or wal mart has one with a white cap that works just as well, and u get more and its cheaper, either one will work
Re: (IslandSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IslandSi »</TD></TR><TR><TD CLASS="quote">sandblast that ****. I tried that paint stripper stuff and it didn't budge. Crazy.</TD></TR></TABLE>
Aircraft remover will not work from my experiance.
aircraft stripper wont touch powder coat at all if its nice qaulity. i just got my wheels back from the powdercoater and he hit the inside of the rim with a hammer and didnt even scuff it.
Re: (KillerEJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KillerEJ »</TD></TR><TR><TD CLASS="quote">go to Home Depot and buy the Jasco Paint Remover... that works really well. </TD></TR></TABLE>
Do you even know what you are talking about?.....
PAINT REMOVER/THINNER,brake fluid and other solvents will not really **** with powdercoat....its a major bitch to get off. Take my advice and get a sandblaster...or rent one.
Re: (Eyewitness)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eyewitness »</TD></TR><TR><TD CLASS="quote">
PAINT REMOVER/THINNER,brake fluid and other solvents will not really **** with powdercoat....its a major bitch to get off. Take my advice and get a sandblaster...or rent one.</TD></TR></TABLE>
Have you ever used it? Probably not. Trust me this **** takes off all kinds of powdercoating. I've used it many times. Just don't get it on your hands or it will start burning your skin. Get the "Jasco Premium Paint and Epoxy Remover" as they have many different kinds.
Re: (JDM EJ1 95)
Have you ever used it? Probably not. Trust me this **** takes off all kinds of powdercoating. I've used it many times. Just don't get it on your hands or it will start burning your skin. Get the "Jasco Premium Paint and Epoxy Remover" as they have many different kinds.</TD></TR></TABLE>
i agree with u. give the thinner some times like 15 mins and it be good to go. do it a few times, it works for me.
Resident powder coater
Depending on powder formulation there is a few ways to remove it. The best way is burn it off, than blast off the fly ash. If it's an epoxy, good luck....bring it somewhere to have it stripped. They will chemical strip it than blast it off with something angular like garnet/slag. Powder is tough stuff but it is sure not indestructable. You do not want to try and blast off powder that hasnt been hit with a chemical stripper or torch. It's a polymer, aka plastic, so it will just melt with the heat generated by the blasting media. You need to damage teh bond between the metal and the coating before blasting will be effective. If you use the chemical stripper from walmart, heat the part up until its warm than spray it down every couple minutes and it will start bubbling. Than scrub it down witha wire brush. Good luck.
