HELP!!!! gauge cluster/turn signal/clock problem.....
Old Mar 23, 2006 | 09:10 PM
emotionisdead's Avatar
Very Emergency!!
Default HELP!!!! gauge cluster/turn signal/clock problem.....
all right guys, i bought a car from my friend and a couple of things are going on. first off, the gauge cluster only has the alternator light on, no oil pressure light, CEL, water temp, tach, e-brake, nothin comes on.
second, the clock doesn't work
third, the turb signals don't work, but the hazard lights do.
my question, is there a common ground that all these circuits would use? i have serached and can't find anything. any help woud be awesome. thanks.
Old Mar 23, 2006 | 09:38 PM
btleier's Avatar
had the same thing happen to me... there's a fuse under the dash... I can't remember the exact one, but it controls all those things.
Old Mar 23, 2006 | 09:42 PM
btleier's Avatar
it's one of them on the left side.... either "back-up light" or the "tail light, instrument light, license light one"
Old Mar 24, 2006 | 07:00 AM
Very Emergency!!
Default Re: HELP!!!! gauge cluster/turn signal/clock problem..... (emotionisdead)
thanks for the help. the instrument lights light up, it's just the gauge cluster lights that don't.
Old Mar 27, 2006 | 08:05 PM
btleier's Avatar
were you able to figure it out?
Old Mar 27, 2006 | 09:46 PM
bostoncal's Avatar
Default Re: (btleier)
could be the bulbs......
* edit..stupid roommate comment. sorry about this
Modified by dfwautowerks.com at 9:34 AM 3/28/2006
Old Apr 8, 2006 | 11:43 AM
B16CRXT's Avatar
Default Re: (dfwautowerks.com)
I'm having the same problem, and My temp gaueg and fuel gauge arent working either. They worked last night and this morning the only thing that works is the alt light.
Old Jun 6, 2006 | 11:17 AM
mckenzie's Avatar
was this problem ever fixed?
Old Jun 26, 2006 | 10:09 AM
saaron34's Avatar
Default Re: HELP!!!! gauge cluster/turn signal/clock problem..... (superpho)
in response to the cluster lights not working, there is a small unlabeled plastic box with a wire harness going to it (i think a 4 pin harness) mounted up underneath the dash, driver side, toward the right. Mine said "AK 22". This thing controls the guage cluster lights.
All that is in there is a small circuit board with the some resistors and diodes, and a nice big power transister.
Mine popped, smoked and fried when I was dumb and plugged the harnesses into the fuse box wrong, trying to do another project. After re-soldering the components inside this AK22 box, the lights worked again.
I sure didn't find anything about this mystery box in any shop manual. maybe this will help a few people.
Old Jun 26, 2006 | 05:35 PM
94eh_6's Avatar
had a similar problem in my del sol...if the car has an after market radio in it make sure the dimmer wire is wired up or taped off...it can ground out and blow a fuse in the under dash fuse box
Old Aug 12, 2006 | 12:41 PM
midnightrice's Avatar
im having this problem on my 97 hatch but its not a fuse problem. I checked all the fuses and they are all good. I bought the car stripped with the cluster harness cut.. it must have shorted something but i dont know what. I installed a new cluster harness and a new cluster but the alternator light stays on. The only parts that work is the cluster lights, turn signals, and high beam. The MIL doesnt come on either. none of the gauges work at all. im lost.
Old Aug 27, 2006 | 02:29 AM
mckenzie's Avatar
up for help for us folks
GroundZer0 336
Jun 26, 2010 07:02 PM
ltran82
Nov 1, 2007 12:58 PM
sirpsychosexy1
Jul 8, 2005 11:28 AM
Slow_Boy
Aug 24, 2004 12:45 PM
Taikonaut
Sep 27, 2003 07:46 AM
