Ls/vtec help~! NOT STARTING.
I JUST PUT IN A B18A N A B16 HEAD. EVERYTHING IS IN. IT STARTS BUT IT JUMPS FOR SOME REASON.. N WHEN I TRY TO CHANGE THE TIMING IT DOESN'T START AT ALL. ANY HELP?
You might have a vacuum leak still even if lines are in...a line could be frayed...however the eff you spell it....I plugged every vacuum port on my manifold. If switch the tps and map sensor hookups and see if it starts up and runs better. Any CEL'S ?
Sounds like a vacuum leak to me. spray carb cleaner around the tb and intake manifold gasket to see if you can find a leak. double check all the vacuum line going into the manifold.
