b16 from hell help
Old Mar 23, 2006 | 04:51 PM
92b16si's Avatar
Default b16 from hell help
also posted this in the crx ef forum
but i thought you guys might now too thanks
dropped in my running b16a3 motor into my brothers std which was already wired and running a d16a6
i just used the b16a3 longblock
used obd0 dizzy pr3 ecu and all obd0 intake manifold sensors
I plugged everything right back up
now i havent wired the knock sensor or vtec
it just cranks like it wants to start but no combustion and makes some attemps to turn but just back fires a bit and dies
P.S. also changed timing belt
but it sounds like its on time
Old Mar 23, 2006 | 08:16 PM
92b16si's Avatar
Default Re: b16 from hell help (92b16si)
anyone
Old Mar 24, 2006 | 06:36 AM
HT Chaplain's Avatar
Loved
are you using obd0 inj?
Old Mar 24, 2006 | 08:37 AM
92redhatch's Avatar
when i put my b16 in my eg. some sensors were bad and 1 injector. So it want to start. Check all your sensors. All your grounds. And see if your getting spark to the plugs. Check to see if the injectors are working. Make sure you have good spark plugs. Also to chack if your distributer is getting power put a test light on the black and yellow wire. You should have power there.
Old Mar 24, 2006 | 09:41 AM
92b16si's Avatar
Default Re: (92redhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92redhatch &raquo;</TD></TR><TR><TD CLASS="quote">when i put my b16 in my eg. some sensors were bad and 1 injector. So it want to start. Check all your sensors. All your grounds. And see if your getting spark to the plugs. Check to see if the injectors are working. Make sure you have good spark plugs. Also to chack if your distributer is getting power put a test light on the black and yellow wire. You should have power there.</TD></TR></TABLE>
I have power in dizzy i have spark and fuel
it is on time motor was working on my car which was taken off just a day before
Old Mar 24, 2006 | 10:52 PM
92b16si's Avatar
checked timing 5 times already im really stumped guys fuel is fine there is spark
Old Mar 24, 2006 | 11:54 PM
92b16si's Avatar
help!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Mar 25, 2006 | 10:25 AM
92b16si's Avatar
bump
Old Mar 26, 2006 | 11:29 AM
92b16si's Avatar
can it be that im running a obd1 dizzy ?
Old Mar 26, 2006 | 12:15 PM
spoolin crx's Avatar
yes obd-0 and obd-1 are different... if you have an obd1 ecu you can use obd1 dizzy
Old Mar 26, 2006 | 12:34 PM
92b16si's Avatar
Default Re: b16 from hell help (spoolin crx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoolin crx &raquo;</TD></TR><TR><TD CLASS="quote">yes obd-0 and obd-1 are different... if you have an obd1 ecu you can use obd1 dizzy</TD></TR></TABLE>
im running an obd1 dizzy with a custom made clip to plugg into obd0 harness and using obd0 ecu
Old Mar 26, 2006 | 04:15 PM
92b16si's Avatar
ttt
Old Mar 27, 2006 | 08:20 AM
92redhatch's Avatar
sounds like a ghetto rig. If you got spark, right timing, fuel and all your fuses are fine. Then it has to be the wiring to the ecu.
Old Mar 27, 2006 | 08:37 AM
92b16si's Avatar
Default Re: b16 from hell help (92redhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92redhatch &raquo;</TD></TR><TR><TD CLASS="quote">sounds like a ghetto rig. If you got spark, right timing, fuel and all your fuses are fine. Then it has to be the wiring to the ecu. </TD></TR></TABLE>
just but an obd0 dizzy still wont turn on
theres fuel spark and timing is right
OneFlyCrxGuy
Nov 23, 2010 06:57 PM
kevbot
Nov 5, 2010 07:52 AM
JDMmadness
Feb 18, 2010 01:43 PM
mcaro
Oct 13, 2008 02:27 PM
97_delsol_Vtec
May 6, 2006 10:12 PM
