Oil pan gasket metal rings
Old Mar 23, 2006 | 09:03 AM
Pompiuses's Avatar
Default Oil pan gasket metal rings
I'm about to reinstall my oil pan with a new gasket.
On the flywheel side of the oil pan gasket there's two holes that's supposed to have metal rings in them (see the pic below). Sadly I lost these metal rings when I took the gasket off. I've bought a new oil pan gasket, but the metal rings did not come with it .
I would like to buy some new ones, but I can't find the part# for them. I can't see them here: http://www.acuraoemparts.com/d...ch=no
Anyone know the part# of these metal rings, or know where I can find them?
Pic of oil pan gasket where the metal rings are supposed to be:
Old Mar 23, 2006 | 09:10 AM
len's Avatar
len
Default Re: Oil pan gasket metal rings (Pompiuses)
You shouldn't need any. Just Honda-Bond and the Gasket.
I've only seen the aftermarket stuff with the metal o-rings.
Old Mar 23, 2006 | 11:04 AM
Pompiuses's Avatar
Default Re: Oil pan gasket metal rings (len)
When I took the gasket off I noticed there were some sealant at the edges/bends on the gasket. Am I supposed to just put hondabond there, or should I put it on the entire gasket?
Old Mar 23, 2006 | 11:10 AM
ITR-00-1457's Avatar
I am sorry Len but you don't need any hondabond on the oil pan gasket at all. no where in the Helms manual does it say to put hondabond there. the metal rings are embedded in the rubber oem gasket, if you squeeze the gasket you will be able to feel them.
Old Mar 23, 2006 | 01:52 PM
01usjdmr's Avatar
Yep unless you got an aftermarket gasket , they're in there.
Old Mar 24, 2006 | 09:12 AM
98DC2R's Avatar
Default Re: (01usjdmr)
I just bought a oem one and found no metal rings inbeded in it?
Old Mar 24, 2006 | 10:56 PM
wildoutwhitegsr's Avatar
Just to confirm what ITR-00-1457 and 01usjdmr have already said the OEM oil pan gasket comes with metal washers inbedded already into it.
Here are a couple of pics showing the metal washers in the OEM gasket I purchased from Len at Baranaco Acura
** don't take this the wrong way Len I'm just trying to help Pompiuses out**
Old Mar 25, 2006 | 06:06 AM
Chris F's Avatar
Dude, I think you do have the metal ring. The OEM one I bought 6 months ago had them too, though it wasn't obvious since they are covered in rubber.
Yours looks the same as mine. Try pinching the center hole, see if there's something hard in there.
P.S. If you haven't done this before: There a GOOD chance one of the old metal rings will stick to the block, and expletive up the seal on your new gasket. Make sure you look for any unusual bumps around the studs in the block.
Old Mar 25, 2006 | 08:16 PM
RPRacing's Avatar
i agree with some above. the honda gaskets do have metal rings in the gasket.
the hondabond you typically see is at the corners where the oil pump and rear seal plate meet with the block and ooze out to the gasket surface. Unless you are reusing a gasket, no hondabond is necessary
Old Mar 25, 2006 | 08:51 PM
len's Avatar
len
My apologies. I grabbed the bag and didn't even feel for the o-ring which is embedded into the gasket itself and looking at the original pic, it looks like it's already there.
As far as the Hondabond goes, I've always used Hondabond between the oil pan and the gasket, not between the flat surfaces of the gasket and the block. *shrugs*
Old Mar 26, 2006 | 12:19 AM
Takumi Fujiwara's Avatar
Some people have had success with hondabond on the gasket, some have not. I've tried both ways and I'm not leaking anymore with no honda-bond. But I know people that always use honda-bond on their oil pan gasket to avoid issues, and they do.
You can't go wrong either way.
94 IntegraLS
May 7, 2013 11:42 AM
db8int3gra
Feb 28, 2009 08:49 PM
miro_gt
Jun 24, 2007 08:02 AM
ringgold
18
Sep 20, 2004 04:28 AM
Just Checking In
Mar 25, 2003 06:06 PM
