if a voltage regulator is faulty what syptoms would be occuring?
Old Mar 23, 2006 | 07:51 AM
B18ceed's Avatar
Default if a voltage regulator is faulty what syptoms would be occuring?
cant get enough spark too keep car running! please help
Old Mar 23, 2006 | 08:40 AM
Tweakmeister's Avatar
Default Re: if a voltage regulator is faulty what syptoms would be occuring? (B18ceed)
Check the cap and rotor first - it's usually just that.
Old Mar 23, 2006 | 09:10 AM
integra3586's Avatar
Default Re: if a voltage regulator is faulty what syptoms would be occuring? (Tweakmeister)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tweakmeister &raquo;</TD></TR><TR><TD CLASS="quote">Check the cap and rotor first - it's usually just that.</TD></TR></TABLE>
most likely, you can get a car to run on just a battery, doesnt even need a alternator to run. (obviously the battery will die and so will the car)
Old Mar 23, 2006 | 02:15 PM
B18ceed's Avatar
i bumped my positive terminal on the battery and ever since then the car has not had enough spark to idle. ive checked all my grounds, had the ignition coil replaced and the icm checked? everyone said the alternator would be the first place check cause its primarily inline with the battery..
fanta!
Dec 7, 2005 10:52 AM
toughlou
Jan 2, 2005 06:38 PM
Acura EL
Oct 12, 2004 04:01 AM
sshaikh01
10
Apr 28, 2004 04:58 PM
Trac226
Aug 21, 2002 11:28 PM
