How would you describe this function
Car had been sitting eating dust for about 1 year and 5 months.
Using a perfectly fine battery from another civic (same battery). good battery.
Car doesn't have enough juice to start up, but if i jump it, it cracks up in half a self.
Drove the car two hours, started it, it cranked up, next day same thing, needs a jump.
What could be the problem. no i don't have my check engine light on.
Re: How would you describe this function (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid »</TD></TR><TR><TD CLASS="quote">Im thinking alternator. Try swapping that out with the batt. and see what happens. </TD></TR></TABLE>
my thoughts exactly
my thoughts exactly
Re: How would you describe this function (zer0_2_6ixty)
check your terminal connections and make sure everything is cleaned and not corroded you could have something wrong in the connections preventing the alt from charging the battery do that first if still no luck i hate to say it but go to advanced or auto zone or something and have them check the alt - its free but sometimes not reliable.. but thats your best bet.
Re: How would you describe this function (punku10)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by punku10 »</TD></TR><TR><TD CLASS="quote">check your terminal connections and make sure everything is cleaned and not corroded you could have something wrong in the connections preventing the alt from charging the battery do that first if still no luck i hate to say it but go to advanced or auto zone or something and have them check the alt - its free but sometimes not reliable.. but thats your best bet. </TD></TR></TABLE>
Re: How would you describe this function (foz)
Don't go to AutoZone or anywhere else like that. They told me I needed a new alternator, but before purchasing one here's what I did; clean more than just the terminal connections...clean ALL of the connenctions that have to do with the charging system from the alternator to the battery. Also check your grounds. If that doesn't work, then I'd say alternator.
Sounds like the alternator
Re: How would you describe this function (sshaikh01)
i had the same problem. it was my terminal but by the time i replaced i had shot the battery. so check your terminal..and all that other good stuff.
I went to auto zone, its not the altenator, they blame it on the battery
But, i think i will clean everything up and than try it.
Re: How would you describe this function (97redex)
If it's the altenator, then why won't the car start up with a perfectly fine battery? Like everyone said, check your connections.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sshaikh01 »</TD></TR><TR><TD CLASS="quote">I went to auto zone, its not the altenator, they blame it on the battery
But, i think i will clean everything up and than try it.</TD></TR></TABLE>
I told you! They're fu@King idiots!
Juan_Mitosis
09-17-2008 09:00 PM
westcoastEJ1
05-08-2006 11:16 AM
