low idle
Old Mar 22, 2006 | 10:15 PM
JDMtype Eg6's Avatar
Default low idle
searched but couldnt find my answer. The thing is, while driving in gear and going to neutral my idle sometimes goes down to 200 rpm, but as i let it idle it goes back to 500-750. Is this normal? because when i first got my car back from a valve adjustment and timing, the car idled at 1000 and stayed to 1k-900 rpm. thanks
Old Mar 22, 2006 | 11:16 PM
midnitesol's Avatar
Default Re: low idle (JDMtype Eg6)
i would get your timing checked again.
Old Mar 23, 2006 | 01:56 PM
started my car in the afternoon and idle was at 1000k on the dot. The weird thing is that my low idle usually happens when its cold. Also im throwing code 1 but i only have one o2 sensor before the cat (no cat).
Old Mar 23, 2006 | 04:39 PM
i think i found the problem. When i changed my intake manifold i remember the iacv was dirty and i tried to clean it a little but pushed the screen in more. Can i take the iacv off to clean the screen without taking off the two coolant hoses, becuase i remember i almost fainted trying to take them off with pliers.
Old Mar 23, 2006 | 04:45 PM
Default Re: (JDMtype Eg6)
pls dont bother with my 1k typo
Old Mar 24, 2006 | 07:47 AM
midnitesol's Avatar
its possible but you might get tired of working in such restricted space. taking it off will give you more ease to clean it. use any lubricant and pry that hose off it should loosen up.
blkspd5
22
Jan 27, 2020 11:55 AM
FloridaCivic
18
Feb 24, 2007 12:23 PM
Chilly61383
16
Nov 12, 2005 05:23 PM
Civic Racer X 7
Jul 23, 2003 07:19 AM
Spade
Jul 1, 2002 10:49 AM
