need some help on removing drive axel nut
K guys im tryin to replace my clutch and I cant get this nut off. I got the passenger side off but i cant get the driver side. I dont have an impact wrench. Im just using a wrench and a breaker bar and the car is moving. Any suggestion on getting that off??
you should of loosened them be4 you put the car up but i had a problem with the pas side on my old 91 accord. i broke to 1/2 inch breaker bars and 3 sockets so i finaly went and bought a 3/4 inch ratchet and long pole and a torch.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skata89 »</TD></TR><TR><TD CLASS="quote">it is on the ground and it still moving. Whats the torch for tho??</TD></TR></TABLE>
do you have you e-brake set? is it in gear? i dont see how it could be that tight.
when i pull my axles i usually for get to loosen that nut before i jack the car up. so what i do is get a base ball bat and wedge in between the seat and the brake pedal. or you can just get a buddy to hold the brakes make sure you have some pressure left in the brake booster or you will have to start the car again.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18B-SC »</TD></TR><TR><TD CLASS="quote">
when i pull my axles i usually for get to loosen that nut before i jack the car up. so what i do is get a base ball bat and wedge in between the seat and the brake pedal. or you can just get a buddy to hold the brakes make sure you have some pressure left in the brake booster or you will have to start the car again.</TD></TR></TABLE>
yea i did something like that and blew out the master cyclinder but as far as the torch it will lossen it up with the heat bascily become unseized
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92DAIntegraXSI »</TD></TR><TR><TD CLASS="quote">
yea i did something like that and blew out the master cyclinder but as far as the torch it will lossen it up with the heat bascily become unseized</TD></TR></TABLE>
explain to me how holding the brake can blow out a master cylinder?
explain to me how holding the brake can blow out a master cylinder?</TD></TR></TABLE>
easy the car was sitting for 6 months it was a old car , NY weather conditions and brake flid was never changed, and yea i had my dad hold the pedal down not running for 25 minutes. i guess it just gave out i dunno seems all the MC's go bad on the old accords anyway
As Back up for 92DAIntegraXSI when metal is heated up it expands, Hence you heat up a nut it expands off of the thread. That is what makes a torch useful in a tight nut situation. He did not get it hot enough to cut it just hot enough to expand it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fliptout2 »</TD></TR><TR><TD CLASS="quote">As Back up for 92DAIntegraXSI when metal is heated up it expands, Hence you heat up a nut it expands off of the thread. That is what makes a torch useful in a tight nut situation. He did not get it hot enough to cut it just hot enough to expand it.
</TD></TR></TABLE> exactly
easy the car was sitting for 6 months it was a old car , NY weather conditions and brake flid was never changed, and yea i had my dad hold the pedal down not running for 25 minutes. i guess it just gave out i dunno seems all the MC's go bad on the old accords anyway</TD></TR></TABLE>
sounds like you already had a faulty MC, looks like you got lucky that the MC failed while the car was stopped rather than in a emergency situation
turbointegrar
Jul 24, 2006 06:36 AM
TheNasty0ne
40
Sep 1, 2005 12:49 AM
