Hondata chipped ECU able to be reburned for Neptune, Crome, etc?
and vice versa? looking to get a chipped ECU for my next setup (turbo), probably run Neptune, but not sure if I can just get a Hondata chipped ECU and write over it with Neptune or not? what are the limitations as far as rewriting an EPROM? can you burn over most chips or do you just need a brand new chip?
also, correct me if Im wrong, P28 has no knock sensor, and P72 has knock sensor?
i can only answer the knock sensor?. you got it right though. p72 also has the iab's that the p28 doesn't have.
Shmaa
Aug 27, 2006 05:30 PM
ghettochild
Nov 3, 2004 08:30 AM
