Trying to make my D15 B8 fast
Old Mar 22, 2006 | 01:59 PM
fakeownzjoo's Avatar
Default Trying to make my D15 B8 fast
What should i do... make list if possible and pics if any!!! "Without going TURBO"
Old Mar 22, 2006 | 02:01 PM
gunnis's Avatar
Default Re: Trying to make my D15 B8 fast (fakeownzjoo)
1. A turbo.
Old Mar 22, 2006 | 02:10 PM
skratchnsnift's Avatar
turbo
Old Mar 22, 2006 | 02:11 PM
bmoua's Avatar
how much money do you have???
Old Mar 22, 2006 | 02:14 PM
professor poon's Avatar
good luck...boost is just about the only thing you can to do that thing for a reasonable price to make it "fast"
Old Mar 22, 2006 | 03:41 PM
novvti's Avatar
turbo the sohc
Old Mar 22, 2006 | 04:27 PM
TurboEM1's Avatar
ummmmmm turbo?
If you insist on not going turbo get...
intake or ITBs or velocity stack, throttle body, intake manifold, valves, springs, retainers, pistons, rods, sleeves, crank, cams, header, highflow cat, exhaust, tuning and after a couple grand youll wish you went turbo.
Old Mar 22, 2006 | 04:34 PM
. a d a m's Avatar
Default Re: Trying to make my D15 B8 fast (TurboEM1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboEM1 &raquo;</TD></TR><TR><TD CLASS="quote">
intake or ITBs or velocity stack, throttle body, intake manifold, valves, springs, retainers, pistons, rods, sleeves, crank, cams, header, highflow cat, exhaust, tuning and after a couple grand youll wish you went turbo. </TD></TR></TABLE>
ITBs on a d-series is a waste of ITBs.
boost it or swap it out
Old Mar 22, 2006 | 04:39 PM
Stop the Beast's Avatar
Unfortunatly, without serious work and a light chassis mid-high 14's are going to be fast for the d15b.
I/h/e, cam/springs, and tuning should be your starting point. That's alone is going to cost about $1,000+ depending on the parts you use.
jk11blueboi
May 12, 2007 08:28 PM
JDMallTHEway
Oct 20, 2004 08:22 PM
civic_hatchback
Jun 5, 2004 01:21 PM
JDMTEG98
Oct 28, 2002 06:32 PM
